Old May 18th, 2019, 15:32
PDBreske's Avatar
PDBreske PDBreske is offline
Re: Hard start; replaced CPS; CEL back on; won't start
So I replaced the Distributor Pick-up Coil (Amazon link: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1) and it's been running perfectly with no engine codes for the past couple days.
Took maybe fifteen minutes to replace the part using only a Phillips screwdriver. Once I was done, I cleared the codes with the new scanner and nothing has resurfaced. I assume this cheap part won't last very long, but at least it was only $17 delivered (next day Prime). I may buy another and keep it in the Jeep, just in case.
Old May 19th, 2019, 06:54
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
I carry a spare brand new genuine Jeep Crankshaft Position Sensor and a used tested good genuine Jeep Cam Sensor in all three of my XJ's.
Originally Posted by bimmerjeeper
Go ahead and slam the liftgate down on a blanket, and see how long you are laughing.
Originally Posted by soyjer
Tim MAY be 100% correct, but why would a person automatically pick him as the expert .....
Old May 20th, 2019, 06:22
PDBreske's Avatar
Update: I replaced the Distributor Pickup Coil (Amazon link: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1) and cleared the engine codes with my new scanner. It starts right up and runs fine. I've been driving it for about four days now and it seems to be fine.
This was an easy fix. Just a Phillips screwdriver and ten minutes work. The part was about the cheapest I could find (also the quickest with Next-Day Prime shipping), so I suspect it won't last more than a couple years, but I'm planning to buy spare OEM parts to keep on hand for the next time these go bad.
Old May 20th, 2019, 06:24
PDBreske's Avatar
Ugh. Sorry about the redundant post. Gee, it sure would be nice if I could edit my own posts.
Hard Start when warm, easy start when cold Pinocpao OEM Tech Discussion 4 December 2nd, 2016 16:50
New engine with no start/hard start. Caboose OEM Tech Discussion 1 January 23rd, 2014 11:20
Hard start / No Start cbwymore OEM Tech Discussion 27 April 9th, 2013 19:07
Need help, replaced NSS, won't start WEJOXJ OEM Tech Discussion 16 October 23rd, 2010 19:11
Replaced CPS...still no start 90xj4x4 OEM Tech Discussion 25 January 29th, 2007 14:11
