Old May 6th, 2019, 16:26
Black1990jeep Black1990jeep is offline
Oil Pan Removal
on my 1990 cherokee, lifted 5.5 inches, I need to remove the oil pan (oil dip stick tube broke off flush, need to hammer it out from inside, already tried bolt extractors on it, stuck tight)
Anyway the factory manuals tells me I need to disconnect the exhaust pipe from manifold, remove starter, disconnect motor mounts, and raise engine to get the pan off.
I appear to have plenty of clearance between the pan and axle as the jeep is lifted 5.5 inches Do I still need to remove the exhaust pipe from manifold if I dont need to raise the motor?
I am hoping to not have to mess with the exhaust and its very rust bolts. Will someone who has done this on a raised jeep let me know?
Thanks!
Old May 6th, 2019, 17:36
tjmotter's Avatar
tjmotter tjmotter is offline
Re: Oil Pan Removal
I removed the pan on my '90 to change the oil pump and and rear main seal. I did not have to touch the top end. IIRC the only challenge I ran into was that the pan wouldn't drop enough to clear the axle but it sounds like the lift should take care of that for you. In my case the answer was to lift the transmission a bit to create enough space to get the pan to clear.
HTH
Todd
Old May 6th, 2019, 18:23
Rick.rob Rick.rob is offline
Re: Oil Pan Removal
Just did mine on my 01 with 5" lift. Didn't have to remove anything besides the pan itself.
Old May 6th, 2019, 18:40
Anak's Avatar
Anak Anak is offline
Stranger
Re: Oil Pan Removal
I think I had to remove the starter on mine, but not the exhaust, nor the motor mounts.
I am only at about 3" of lift.
Baby it's cold outside.
Old May 17th, 2019, 17:23
denverd1's Avatar
denverd1 denverd1 is offline
Oil Pan Removal
At 4.5 inches on a 98. Pan came out without removing anything
Chili Pepper '98
4.5" lift, locked on both ends, 33s
10K winch and a lot of skinny pedal
Old May 17th, 2019, 18:44
devildog0's Avatar
devildog0 devildog0 is offline
Re: Oil Pan Removal
I dropped the pan on a stock 95 XJ by just supporting the jeep on the "frame", taking off the tires and letting the axle droop, removing the starter and taking off one large bolt/nut on the bottom driver's side of the flexplate cover/bellhousing. It lightly drug on the axle but still came out.
1995 XJ Country/4.0L/AW4/231/UpCountry Suspension
2004 Suzuki DL650 VStrom/1978 Suzuki GS1000E/2003 Yamaha TW200
1982 Suzuki GS850G (barnfind project)
Old May 18th, 2019, 06:02
4x4JeePmaNthINg's Avatar
4x4JeePmaNthINg 4x4JeePmaNthINg is offline
Re: Oil Pan Removal
X2 on this, I'm lifted, but if you can support the frame and droop the axle as much as possible your good to go.
95 aw4 removal beastlydumass OEM Tech Discussion 9 June 5th, 2011 13:00
Engine Removal vs Tranny removal stephenspann27 Modified Tech Discussion 28 May 30th, 2008 12:09
Oil Pan Removal Help! bkhudgins OEM Tech Discussion 3 November 28th, 2007 14:23
90 4.0L oil pan removal CHEROKEEPEOPLE OEM Tech Discussion 9 October 14th, 2007 20:24
AC Removal AngryDog OEM Tech Discussion 2 February 18th, 2005 03:06
