Old February 17th, 2019, 21:03
devildog0's Avatar
devildog0 devildog0 is offline
Re: differences in 91-95 xj
Originally Posted by Club31XJ View Post
The pins are the same. I know one difference that the 95 had was that it had an airbag in the steering wheel. Otherwise pretty much the same I believe
Its a fully mechanical airbag so no electronics to worry about there.
Sent from my SM-G892A using Tapatalk
1995 XJ Country/4.0L/AW4/231/UpCountry Suspension
2004 Suzuki DL650 VStrom/1978 Suzuki GS1000E/2003 Yamaha TW200
1982 Suzuki GS850G (barnfind project)
Old February 19th, 2019, 10:23
kastein's Avatar
kastein kastein is offline
Location: Central MA - keep going till the road turns to dirt, then listen for banjos
Originally Posted by WB9YZU View Post
Not likely.
'95 was a crossover year for the drivetrain/ electronics.
'96 was all new style.
devildog0 is mostly right here. Not much changed in 95 aside from what I mentioned... all the critical stuff will Just Work. A bunch of sensor connectors changed in that rough year range, but the ECU plug's the same and the resistance curves are (to the best of my knowledge) the same.
My yard looks like Sanford & Sons.
Please do not PM me about the AW4 info thread unless you have a truly unique question that is not covered by it or info to add. I do not respond to questions answered by the thread.
Definitely do not hunt down my phone number at 3AM, text me about it, and then threaten violence when I am not helpful. It will not get you what you want.
CTeunuch: Sometimes I really wonder if this sport makes you insane, or it just attracts the mentally unstable.
4.0 i-6 DIFFERENCES? bcmaxx OEM Tech Discussion 31 May 12th, 2011 14:53
Any differences between '95 and '96 my? The Adam Blaster OEM Tech Discussion 27 October 19th, 2010 07:47
Differences between '01 XJ and '99 XJ woodkrawler OEM Tech Discussion 6 July 30th, 2010 17:39
CPS differences? OverlandZJ OEM Tech Discussion 2 April 20th, 2007 09:03
tie rod end differences scottsxj OEM Tech Discussion 0 June 13th, 2005 20:33
