Old February 12th, 2019, 03:55
RedMaineXJ RedMaineXJ is offline
Unhappy Lessons learned from online parts ordering
I ordered a Carter fuel pump assembly from ebay last week to solve my slow start/priming issue.
The box arrives, and with excitement I cut open the box only to discover an Airtex inside the Carter box!
Proceed with caution fellow squares..
Old February 12th, 2019, 05:04
Ralph77 Ralph77 is offline
Re: Lessons learned from online parts ordering
That is so not right.
Not that I don't order parts online but I pick and choose.
One example is when I needed a new stater for my '00 XJ.
I bought a brand new Napa one. Not remaned. With my discount it was still not cheap. Could have bought one online, other local retailers, etc for maybe as cheap as half the price. Know what. It comes with a lifetime warranty. Which will not be a problem being honored if there every is a problem. With the exception of new ones not being made anymore and I might have to take a remaned one. Not worth the trouble in mind. Especially if for some reason I ordered the wrong one. It was the right part number but packaged wrong. Etc.
Now a Carter pump is a Carter pump. Does not matter where you get it from. At least it should be. Just sucks what happened to you.
Old February 12th, 2019, 07:10
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Theft by swindle, eBay will get your money back.
Originally Posted by bimmerjeeper
Go ahead and slam the liftgate down on a blanket, and see how long you are laughing.
Originally Posted by soyjer
Tim MAY be 100% correct, but why would a person automatically pick him as the expert .....
Old February 12th, 2019, 13:58
Heavyopp Heavyopp is offline
Especially if you used PayPal
No way I’d stay quiet about that — get your money back then make the seller send you a shipping label if he wants his parts
Old February 12th, 2019, 18:51
Green Mesa XJ's Avatar
Green Mesa XJ Green Mesa XJ is online now
eBay gets a lot of returned merchandise, I mean being sold there. There a resellers taking a chance buying crap returned to amazon, Best Buy and Walmart, once place was called mad Cheetah and was amazon returns, I know because I saw a ring kit I got from warehouse deals (Amazon’s in house reseller of open packaged items) ended up on eBay via Mad Cheetah, I know it was the same kit because 5 of the 6 sets were perfect and new and one was obviously used. But I also snapped up some great deals on tools amazon let go to cheetah.
That said there are plenty of scammers purposely mislabeling parts to make a quick buck. Use the PayPal and eBay buyer protections, it is why they are there and they work in your favor.
Old February 13th, 2019, 02:48
alwayzAMC alwayzAMC is offline
your slow start/prime issue is likely your regulator ontop of the fuel pump, or a leaking injector/ injector o-ring
Old February 13th, 2019, 08:08
Update: you were right, the seller sent a return label and will refund the money. Good thing!
Old February 13th, 2019, 08:09
Think so? I have bloodied my fingers on forums about the long crank start issue, and I thought the pump assembly contained the check valve causing it
Old February 13th, 2019, 08:43
i am not sure if it contains the check valve, but i do know you can purchase the check valve individually.
i have replaced it on both my 99 and 00, if you can get a hold of a fuel pressure tester, check your pressure, if it is at 49 psi your pump is likely good.
another tip, buy new fuel tank straps, maine winters are very hard on them, it will save you hours of swearing, and many bloody knuckles.
Old February 13th, 2019, 09:51
Yeah I'm that guy that cleans everything, will wipe out the tank, replace clamps, etc with new ones. I do a job once and theoretically I don't have to worry about it again for a long while.
Old February 13th, 2019, 10:47
devildog0's Avatar
devildog0 devildog0 is offline
Online or in person you can always get scammed and not know it.
How many people looking at oil filters do you think grab the more expensive filter and swap it into the supertech or fram box and no one notices till they get their new expensive filter box home open it and it's orange
1995 XJ Country/4.0L/AW4/231/UpCountry Suspension
2004 Suzuki DL650 VStrom/1978 Suzuki GS1000E/2003 Yamaha TW200
1982 Suzuki GS850G (barnfind project)
Lessons learned robbieyukon Jeep Street and Performance 3 May 25th, 2010 13:40
Lessons learned jimgrms Colorado Chapter 9 September 22nd, 2009 19:02
Lessons Learned Alienspecimen OEM Tech Discussion 5 September 14th, 2009 07:30
Two lessons to be learned- SCW Non-Tech / Off Topic 13 December 13th, 2007 20:39
Ordering parts online... LittleAnthony88 OEM Tech Discussion 3 October 17th, 2005 07:56
