Old February 11th, 2019, 11:03
ditchdrift ditchdrift is offline
Magical backwards spinning mechanical fan?
LOL, i think the fan clutch is very dead on my xj.
Old February 11th, 2019, 16:26
kastein's Avatar
kastein kastein is offline
Location: Central MA - keep going till the road turns to dirt, then listen for banjos
Re: Magical backwards spinning mechanical fan?
I would say you got every mile out of that fan clutch, yeah.
It looks like a 96-98 ZJ though I think. It could be a YJ but wouldn't have that style power steering pump... maybe a TJ? Haven't worked on one of those in a few years.
Either way, same parts/very similar parts, looks like you found your cooling problem.
My yard looks like Sanford & Sons.
Please do not PM me about the AW4 info thread unless you have a truly unique question that is not covered by it or info to add. I do not respond to questions answered by the thread.
Definitely do not hunt down my phone number at 3AM, text me about it, and then threaten violence when I am not helpful. It will not get you what you want.
CTeunuch: Sometimes I really wonder if this sport makes you insane, or it just attracts the mentally unstable.
Old February 11th, 2019, 19:29
Nope. It's my 4 cylinder xj. It only has 110k on it. Was wondering why the temp climbs at idle. I just finished rebuilding the engine after the previous owner seriously jacked it up.
Old February 13th, 2019, 13:13
kastein's Avatar
Well I stand corrected then! For some reason I never realized that the 4cyl had the fan run off the water pump instead of the accessory bracket pulley. Thanks, I learned something today.
Old February 16th, 2019, 10:18
Ecomike's Avatar
Ecomike Ecomike is offline
NAXJA# 2091
Wow, a 2 door 4 banger, that has to be rare.
Quote=8Mud: "Go ahead and put up the best fence you can build, I'll bet on some Mexican with a few dollars of nails and a pile of scrap lumber."
34 MPG , '85 2WD Cherokee Pioneer with custom installed, 64 hp, 2.2 L Nissan SD22 Diesel 5 spd Manual; & 4 Renix XJs, '87 Wagoneer 4.0, 4WD, 89-Cherokee, 4WD, '87 Cherokee 2WD, & '89 Cherokee Pioneer 2WD, all 4dr. #2091
Old February 18th, 2019, 09:24
I think it is, I work on vehicles professionally and never seen another 2 door, 4 cyl, 5 speed, 4x4.
Old February 18th, 2019, 09:30
Ecomike's Avatar
NAXJA# 2091
Well I found a feller in Galveston on Facebook this weekend with a Comanche 2 door with the GM-V-6 with a Wagoneer face on it. Not sure about the tranny or 4x4 part.
Old February 18th, 2019, 10:56
I'd be impressed if it was a 4dr. Hah
Old February 18th, 2019, 11:06
Ecomike's Avatar
NAXJA# 2091
Good point, I missed that, LOL
Comanches are rare. One with a V-6 and Wagoneer front face/headlights assy is one I have never seen before.
Old February 18th, 2019, 21:12
lawsoncl lawsoncl is offline
https://www.cherokeeforum.com/f88/le...manche-249647/
Old February 18th, 2019, 22:56
Originally Posted by lawsoncl View Post
Haha. Not factory tho. Impressive none the less
Old February 19th, 2019, 09:26
kastein's Avatar
Wish I could order one of those from the factory, I'd be in line right now.
Yeah, 4cyl 5 speed 4x4 is pretty rare, I have only seen a few 4cyl 5 speed and most of them were RWD. I would say the only rarer option was 4cyl 4 speed auto (87-90 only) 4x4 with the 4.56 gears... 4 or 5 of my friends have seen those in the wild but I've never spotted one in ten years of junkyard scrounging.
Where are these magical junkyards? EvoColli SoCal Chapter 18 July 4th, 2009 00:02
MAGICAL XJ makkman OEM Tech Discussion 5 April 10th, 2008 19:51
magical trackbar destroyer Archdukeferdinand Modified Tech Discussion 22 March 21st, 2007 19:27
magical xj 90xj06 OEM Tech Discussion 3 August 25th, 2006 20:32
