Old February 7th, 2019, 17:10
mgrabow mgrabow is offline
Exhaust Flange
So I purchased some so called "direct fit" exhaust parts. The walker 53440 front pipe that crosses over from one side of the truck to the other has some odd 3-hole flange on it. I had a Magnaflow universal cat already boy the standard 3-hole flange adaptors don't match up to the walker flange.
I can weld a standard flange on the walker pipe or try to find or make a 3-hole adaptor for my universal cat. Anyone know what this walker flange is called?
Old February 7th, 2019, 17:11
Re: Exhaust Flange
here is a link
http://www.walkerexhaust.com/catalog...g-lookup/53440
Old February 8th, 2019, 01:16
Ralph77 Ralph77 is offline
Re: Exhaust Flange
So what year XJ do you have? Cause that is a '00 or '01 pipe. Thinking for a build date of after 1/00. Not sure about that though. I am aware of an Walker adapter to put a slip on muffler behind the stock rear cat but not one to connect that down pipe to a slip on cat.
Old February 8th, 2019, 16:46
Re: Exhaust Flange
its a 00 xj. Rather than welding a standard 3 hole flange onto the exhaust pipe I would prefer to weld up a flange to the front of the cat. If I could just find this odd ass flange I would be all set.
Old February 9th, 2019, 01:17
Re: Exhaust Flange
If I understand you correctly I have never seen an adapter that will match the flange at the end of that down pipe. Only thing that comes to mind is you finding an '00 in the boneyard with the rear cat on it and stealing the front flange off that.
Problems I picture trying to do that are pretty sure a boneyard can't sell a used cat. Even if you had an in chances are they were already removed for scrap cause of their worth so finding one could be difficult. Not to mention if that idea would even work.
Old February 9th, 2019, 06:48
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Re: Exhaust Flange
Naturally, the simplest solution is to buy a direct fit cat. Otherwise, find a mating flange, or a matched pair of flanges, from someplace like Summit ( https://www.summitracing.com/search/...haust-flanges? ) and install them both, or stop by your local exhaust shop, they will either have what you want, or will be able to fabricate something that will work.
Originally Posted by bimmerjeeper
Go ahead and slam the liftgate down on a blanket, and see how long you are laughing.
Originally Posted by soyjer
Tim MAY be 100% correct, but why would a person automatically pick him as the expert .....
Old February 16th, 2019, 06:21
denverd1 denverd1 is offline
Exhaust Flange
Hit an exhaust shop. They can cut n weld a new flange. Take your old pipe if you have it
Sent from my SAMSUNG-SM-G930A using Tapatalk
Anybody ever add an exhaust flange in? wishihad1 Modified Tech Discussion 5 January 16th, 2014 21:44
4 bolt exhaust flange blenny OEM Tech Discussion 4 November 22nd, 2013 11:47
exhaust flange part number? ehall OEM Tech Discussion 10 May 26th, 2011 20:35
dynomax exhaust flange for 00 H8PVMT Wanted: Private Party Only 3 May 19th, 2011 14:57
exhaust flange nut size? Tampa_XJ OEM Tech Discussion 2 November 7th, 2005 17:02
