Old September 3rd, 2018, 08:58
Afireinside Afireinside is offline
Re: 3" to 4.5 rear lift opinions
I've got a set of IRO 1"/1.5" shackles(NIB) if your interested in going that route!
Which ones? How much? $
Old September 3rd, 2018, 09:15
RCP Phx RCP Phx is offline
PM sent
Old September 3rd, 2018, 09:59
Have you installed these springs to see what they netted?
What brand are they?
Old September 3rd, 2018, 11:41
They are 3" zone rear springs. 19 3/4 from center of hub to edge of factory flare.
Well used and flexed several times.
Old September 3rd, 2018, 12:07
That would only be about 2-1/2" of net lift per.......
https://naxja.org/forum/showthread.php?t=912893
Old September 3rd, 2018, 12:26
Yeah depending how I park lol. I'm probably about 2 and 3/4 if I parked level. Not too bad for what I need. So it sounds like I should be looking for a 1.5 shackle lift?
Thanks
Old September 3rd, 2018, 13:01
No it's just a indicator of how the springs are built. I have no experience with "Zone" but RE springs always deliver more because they accounted for additional vehicle weight. If your already down a 1/2", it will effect how is does with longer shackles. It you get 1" out of 1" shackles, you may only get 1-1/4" out of 1-1/2" shackles.
Old May 13th, 2019, 15:30
Ok so summer is here and hopefully I'm actually going to do this lol. I have collected all my front end parts. Time for the rear again. What are the best options for my need. I re-read and can someone please tell me about shackle replicators? I'm thinking those and an extended shackle. I would like to gain roughly 2" in the rear.
Thanks
Old May 13th, 2019, 15:31
Shackle re-locators lol
Old May 14th, 2019, 09:15
lazyxj's Avatar
lazyxj lazyxj is offline
NAXJA Member #1310
https://hdoffroadengineering.myshopi...relocation-kit
What are you planning doing to control the rear driveshaft vibes? 4-1/2" is too high a lift for a dropped transfer case, you should be installing a SYE and CV rear driveshaft.
Both XJs are still Real XJs http://www.naxja.org/forum/showthrea...hlight=real+XJ
01 Sport, Russ Pottenger 4.6, AW4, 4" lift, 33 X 10.50 KM2, 4.56-8.25 TruTrac, D-30-E-Locker with alloy shafts, Hidden M8000 winch, Vanco front and ZJ rear disc brakes, Frame stiffeners, Lots of armor, Towing baseplate. http://www.flickr.com/photos/lwade/c...7603770130683/
1997 Country, Mostly stock, 2" lift, Engine mods, NP242, Towing baseplate
Old May 14th, 2019, 10:11
TORC811's Avatar
TORC811 TORC811 is offline
Originally Posted by Empty_Pockets View Post
A shackle relocation bracket and extended shackles is the best way to get you where you want and keep a nice ride.
I will 2nd this! Lift shackles are the way to go over blocks. They will most likely give you a poor shackle angle and ride quality on the road. Pick up a set of shackles and brackets. I believe Ironman 4x4 sell theirs as a kit.
01 XJ - Rock Link, 4.56s & Treps
88 MJ - In rebuild hibernation
Old May 15th, 2019, 22:34
ingenio ingenio is offline
x4....
extended shackles & HDO relocation bracket...
off course you will need to address the SYE and other sh*t.
good luck
RC 3" Lift - Sagging Leafs? Need opinions on where to go from here. nwatters OEM Tech Discussion 11 April 3rd, 2017 17:29
RC 3" Lift - Sagging Leafs? Need opinions on where to go from here. nwatters Modified Tech Discussion 4 April 1st, 2017 10:46
3" lift opinions dark92xj Colorado Chapter 15 April 12th, 2012 17:37
Need opinions on a 6.5" lift moneypit Modified Tech Discussion 17 March 27th, 2009 10:30
Looking for opinions on a 2"lift... shouston Modified Tech Discussion 18 October 8th, 2008 20:36
