Old March 14th, 2019, 09:23
GSequoia's Avatar
GSequoia GSequoia is offline
Everyone says I'm a jerk.
Re: Gratuitous Lack Of Moderation - A little stroker build
All of my AMC XJ's have been titled as Station Wagon.
All of my Chrysler ones have been titled as Sport Utility.
My 89 is a station wagon and my 96 not but, oddly enough, I seem to recall my dad's 99 says station wagon.
Prior President & Prior SoCal Chapter President
Originally Posted by Bent
Us normal people...
Old March 14th, 2019, 10:10
RCP Phx RCP Phx is online now
Russ installs the hardware with what he calls 'peanut butter' which is a compound specifically to avoid galling the aluminium threads on the head.
Since you have a aluminum head, I'm curious why you didn't go with studs?
Old March 14th, 2019, 10:42
cal's Avatar
cal cal is offline
NAXJA Warranty Voider
I asked Russ about it. He said that we are a LONG ways off from needing them at this compression, that they are more trouble and make it near impossible to R&R the head in the car. Several downsides, no upsides.
I had offered to buy stud kits for both the head and mains, but he was pretty insistent.
Old March 14th, 2019, 12:06
Not head studs, rocker arm studs!
Old March 14th, 2019, 12:17
cal's Avatar
cal cal is offline
Oh. I have no answer there. There's probably just no benefit and he doesn't want to do the extra work.
Old March 14th, 2019, 12:59
The benefit is not screwing and torquing on aluminum!
Old March 14th, 2019, 13:26
Wayne Sihler's Avatar
Wayne Sihler Wayne Sihler is offline
My newest 99 is titled >Sport Utility<. And that was today.
Wayne
Member#17
NRA Life member, AARP NovaJeepers
96XJ,4.0,AW4,D30/D44,4:10s,Detroit,4.5" lift 33,s
Old March 14th, 2019, 14:05
TRCM's Avatar
TRCM TRCM is offline
Here in VA, they want you to title any SUV as a station wagon.....the logic is you can't stack a load higher than the roof like you can a pick up truck.
The problem with that is, as soon as you do, they can ( and will) ticket you for bumper height, as no station wagon I am aware of meets the required weight limits to have a bumper higher than about 20" above the ground.
Most SUVs back then were well above that, especially if 4WD.
My 79 Ramcharger (see avatar pic), when it still had the stock top on it, was sitting on 38" ground hawgs.
They wanted me to register it as a station wagon. I explained the problem, and we agreed to title it as "Ramcharger".
Had a friend who got a ticket for bumper height in a stock bronco (no lift) on 31's. It was registered as a station wagon. I told him to get it registered as a Bronco instead of station wagon, which he did, and the judge threw the ticket out.
I know the cowl on my 88 & 96 both say truck.....but VA won't let me register them as such.
Old March 14th, 2019, 15:41
cal's Avatar
cal cal is offline
or you could just not fail when torquing
Russ has been cutting me a hell of a deal on this one. I'm not going to tell him what to do.
Old March 14th, 2019, 15:42
cal's Avatar
cal cal is offline
Not to mention he's working around my schedule on it so that I can document it for Naxja. He only keeps two engine stands in the shop and I've had one of them tied up for 6 weeks.
Old March 14th, 2019, 22:34
StinkyFab's Avatar
StinkyFab StinkyFab is offline
NAXJA Supporting Vendor
You should have stolen that one that we just bought for my motor
Dallas Ashley
WWW.STINKYFAB.COM
Motor Mounts, Fabrication tools, and Custom stuff for your Jeep!
Old March 14th, 2019, 22:35
GSequoia's Avatar
Hell if it would speed up proaction I'd give him one!
Us normal people...
Old March 15th, 2019, 07:56
cal's Avatar
cal cal is offline
Question Re: Gratuitous Lack Of Moderation - A little stroker build
It's not an issue of stands, it's in issue of space
Old March 15th, 2019, 08:17
sandfreestyle sandfreestyle is offline
If Russ would clear out the backyard and garage of unused stock parts and projects, albeit some great projects, he could create a ton of room.
Old March 15th, 2019, 09:10
cal's Avatar
cal cal is offline
That wouldn't change the amount of room in his shop, and having more room in the shop wouldnt' do much to help production.
What he really needs is an assistant who can run errands, clean parts and handle shipping. We've been discussing some options.
Stroker build kf_chris Modified Tech Discussion 33 January 4th, 2010 20:21
99 xj stroker build WHITE93 Modified Tech Discussion 1 May 2nd, 2009 11:25
4.6L Stroker, Help me build it please! XJoshua Jeep Street and Performance 277 February 28th, 2009 00:18
Stroker Build missionstroker Jeep Street and Performance 15 December 12th, 2007 07:08
Want to build a Stroker? robert stalberger For Sale: Private Party Only. XJ ITEMS ONLY 1 September 12th, 2006 14:08
