Old February 14th, 2020, 17:40
xjnp242 xjnp242 is offline
4.0 rebuild, 243 hp, 286 ft-#'s torque!
Always dreamed about souping up my 4.0.
A LS or other swap out of the question.
Don't know if this has been posted here before. I did a search and nothing came up.
If it was posted before maybe some of the newer members here would get a kick out of this video. I sure did.
https://www.youtube.com/watch?v=sm1xzrapgGs
Old February 14th, 2020, 19:41
bajabronco bajabronco is offline
Re: 4.0 rebuild, 243 hp, 286 ft-#'s torque!
If you can stroke it, you can get some really great numbers from a 4.7! Better than the engine dyno numbers from the video. I think that RCP Phx recently dyno'd his stroker after his rocker swap and got some really solid HP and TQ numbers all the way across the RPM band.
Old February 15th, 2020, 04:53
RCP Phx RCP Phx is offline
Yes and it cost a lot more for the stroker if you are going to do right anyway.
My recent dyno was 350hp/400 ft/lbs torque.
Old February 15th, 2020, 06:45
I meant to say "it Doesn't" cost a lot more for the stroker! Remember that Edelbrock head alone is almost $2k, if you spent that much with Russ you would see a lot more HP from a big valve fully ported head with a matching ported intake manifold.
Old February 15th, 2020, 07:34
jmg222 jmg222 is offline
to be honest, if I were going to do it all over again... I'd go with a stoker.
you just don't NEED the 400+hp on the trails you get from a v8 sbc -- and at the really, really low rpms where we spend most of our time, a 4.0 is going to perform just as well as a 5.7.
don't get me wrong, I love my sbc and the sound turns heads, but … im constantly chasing crap down, everything is a one-off fab job, and the install itself is not all that easy (mostly because of the geometry of the engine bay). and at this point, I only have it registered to tool around towns when I'm at the trails so I don't have to unhook my trailer, so any benefit I get from additional power for the street is lost. Plus a stroker is unique, hardly see any on the trails.
good luck and keep us posted.
Daily drive: 2018 Jeep Grand Cherokee TrackHawk; stock (for now)
Trail ride: 1988 XJ: Motor/plumbing/electrical: '19 ZZ6 350 sbc, 420HP/405 lb-ft; holly performer EPS, Terminator EFI, headers, novak aluminum radiator; MSD ignition
Drive train: d30 front, F8.8 rear, 4.11 gears, np242 transfer case, rusty under-armor; fully locked with detroit lockers; Chevy 700r4 tranny, 35" MT's
Old February 15th, 2020, 12:08
lazyxj's Avatar
lazyxj lazyxj is offline
NAXJA Member #1310
Several years ago, my friend ask me up help increase his 1997's 4.0 power.
He didn't want to remove and build the engine so I took a different approach.
The 7120 head was removed and taken to an old-school, local speed shop, Valley Head Service, a place I had been using since being a teenage in the 60's.
http://www.valleyhead.com/heads.html
The head and late model intake manifold were ported, polished and flow matched, with an emphasis on maintaining air good flow at low RPMs.
The stock cam fit this goal.
While the head and intake were at the shop, a full Banks exhaust system, from header to exhaust pipe, was purchase and installed. A 62mm throttle body was also installed.
Once reassemble, this really woke the 4.0 up. At WOT, it pulls strong from an idle all the way to 5200-RPM, to where the computer shifts it.
It's how the engine could've been built from the Factory and is a lot more fun to drive. I now own this XJ, bought from my late friend's estate. I prefer driving it on the street, compared to my built 2001 with a 4.6 stroker. The 97 is much lighter, lower, narrower and easier to throw around, the perfect around-town car.
Both XJs are still Real XJs http://www.naxja.org/forum/showthrea...hlight=real+XJ
01 Sport, Russ Pottenger 4.6, AW4, 4" lift, 33 X 10.50 KM2, 4.56-8.25 TruTrac, D-30-E-Locker with alloy shafts, Hidden M8000 winch, Vanco front and ZJ rear disc brakes, Frame stiffeners, Lots of armor, Towing baseplate. http://www.flickr.com/photos/lwade/c...7603770130683/
1997 Country, Mostly stock, 2" lift, Engine mods, NP242, Towing baseplate
Old February 15th, 2020, 13:22
4x4JeePmaNthINg's Avatar
4x4JeePmaNthINg 4x4JeePmaNthINg is offline
Did you by chance ever see the before at the tires power for comparison ?
Old February 15th, 2020, 13:26
Cummins90 Cummins90 is offline
Let me know if you want bolt on turbocharger parts. PM me.
Old February 15th, 2020, 15:00
No, there's almost now way because of the electronics to do that, I also wasn't going to haul a motor I just built and to find someone that could do a engine dyno!
Old February 15th, 2020, 18:06
What is puzzling at least to me is why the typical Jeeper would want to do a LS or other engine swap when an appreciable amount of power can be had by stroking or just plain souping up the lowly 4.0.
Yeah ok, there's the bragging rights of a V8 in an XJ!
With an engine swap, there's the headache of procuring/rebuilding the swapping engine, cabling, adapters, drive shafts, motor mounts, misc. PITA's and the electrical/PCM nightmare.
Old February 18th, 2020, 11:27
jrowell's Avatar
jrowell jrowell is offline
By far the best thing I did to my XJ was the Russ Stroker... He says it puts you in the neighborhood of 300hp. My jeep is so much more fun to drive now... love it!!!
Old February 18th, 2020, 14:45
puttzer's Avatar
puttzer puttzer is offline
NAXJA Member #3000
More info on Russ please, website or contact info? Looking at doing a stroker in my 98.
98 XJ 4.0 AW4 231
Old February 18th, 2020, 15:21
jrowell's Avatar
https://www.naxja.org/forum/showthread.php?t=1152254
Old February 18th, 2020, 15:44
He doesn't have a website of his own ..........
Russ Pottenger
531 N. Lyall Avenue
West Covina, California 91790
Work (626) 967-1000
Cell (626) 673-2203
Email: RussBnBracing@yahoo.com
Old February 18th, 2020, 20:54
https://www.jeepstrokers.com/forum/
the man knows stuff..... built one or two maybe..
Torque/Torque Pro Manual 5-90 Non-Tech / Off Topic 19 January 30th, 2013 16:58
Pinion Nut Torque vs Bearing Preload Torque??? Zeke23 OEM Tech Discussion 3 July 28th, 2008 14:47
TORQUE? BigRed86 Modified Tech Discussion 3 February 15th, 2008 07:13
Lug nut torque scoobyxj OEM Tech Discussion 2 September 25th, 2004 19:34
AW-4 rebuild "special" tools/ torque converters TJS93xj Modified Tech Discussion 3 April 13th, 2003 20:35
