Old February 8th, 2020, 10:54
sdspearo's Avatar
sdspearo sdspearo is offline
Atlas2 with AX15: Who's done this?
Which shifters do you have...XJ shifters or universal kit?
Was the 1" spacer required?
I have a '96 and prefer to not hack up the center console plastic too much.
Searched for photos but photobucket pretty much screws that up.
'96 XJ: Locked up D44's on 35" BFG's, ChroMo axles, 6" lift w/ 3 link front, 4 link rear, AX15, Internal cage, DIY beadlocks, hydro assist, big ass stinger!, ...
Old February 9th, 2020, 10:03
Black1990jeep Black1990jeep is offline
Re: Atlas2 with AX15: Who's done this?
I have an AW4 and Atlas. make sure you seal up any tunnel holes you cut very well, a lot of hot air can blow thru into the cabin if not sealed.
Old February 12th, 2020, 20:21
#S194's Avatar
#S194 #S194 is offline
Sierra Chapter President
The spacer is definitely required. Helps with the front driveshaft angle since itís much shorter than stock. I used the universal shifters, the XJ ones are goofy. Iíll see if I can find some pictures.
Originally Posted by GordoSmasho View Post
Tim's junk is impressively beefy. TWSS
Old February 12th, 2020, 22:26
sdspearo's Avatar
Hey Lou, any pics you can send would be great!
Especially curious of how much clearance there is between the atlas shifters and the ax15 stick. Seems like clearance/interference may be an issue unless you put a funky bend in the shifters?
Yesterday I ordered an Atlas2 with the XJ shifters (per AA recommendation) but I can easily change it since the lead time is 6wks. I'll request the spacer too.
Using 2WD AX15 X-member and mount with 4WD AX15 1987Comanche OEM Tech Discussion 2 April 8th, 2014 04:23
90' Ax15/231 - 92' Ax15/231 same splines? Bronzewyrm OEM Tech Discussion 2 July 17th, 2009 18:53
91 ax15 to newer ax15 swap 1sickhick NorthWest Chapter 0 January 16th, 2008 21:54
