Old January 6th, 2020, 09:24
jk_surgeonfish jk_surgeonfish is online now
ARB Rear locker popping...
Trying to research as much as I can on this before spending any money.
I have a TJ Dana 44 in my XJ. It has ARB (model RD113) with 33 chromoly splines. When engaging the locker is seems to be fine going straight but when making a left turn in dirt it makes a horrible popping metallic sound. It sounds like it is slipping.
The compressor will hold air for >20 min so there is no leak there. I have not validated the actual pressure it is putting into the locker yet. Not sure the easiest way of doing that.
What I have read online (1 forum post) is that the symptoms point to a worn clutch gear in the locker.
Has anyone had similar issues? Any suggestions on further things to troubleshoot is appreciated.
Old January 6th, 2020, 09:43
RCP Phx RCP Phx is offline
Re: ARB Rear locker popping...
I would find it hard to damage the clutch gear unless it has not been fully engaging for a long time. I would definitely look into the air system.
Old January 6th, 2020, 10:05
Thx. Any suggestion on how to verify pressure at the locker? I have to look up what min pressure is as well.
Old January 6th, 2020, 10:15
I would start by pulling the diff cover, you should be able to see, feel, and hear the engagement.
Old January 7th, 2020, 08:39
4x4JeePmaNthINg's Avatar
4x4JeePmaNthINg 4x4JeePmaNthINg is offline
is it continuous popping or just one pop? it takes a moment for the locker to disengage and if your turning immediately after disengaging the locker, the disengagement may be harsh.
as stated above I would start by cycling the locker and do check the air line from the pump to the diff for leaks, as well as the locker for engagement. you can put it on jack stands to be sure it engages.
if you want to measure psi out of the pump just piece together a gauge with the same quick fitting. I believe they run ball park 70-100psi.
Old January 26th, 2020, 20:15
I finally got around to pulling the locker out. The clutch gear is indeed worn. The edges are ramped when they should be 90degrees and sharp. I put in a new clutch gear, bonded seal and o-rings since I had it apart. I guess I got lucky as the carrier practically fell out of the housing. I was getting ready for a battle to get it out.
Old January 28th, 2020, 09:07
just curious but did you use the newer o rings, they look like an X, kinda like weed trimmer line?
Old January 28th, 2020, 11:50
Yes. That is what they looked like to me.
Old January 29th, 2020, 16:42
artinprospect artinprospect is offline
How long/how many miles have you had the locker in there? Odd that should wear out quickly.
Old February 5th, 2020, 06:23
8yrs or so.
Old February 5th, 2020, 06:42
Did the axle come with the locker already installed?
Old February 6th, 2020, 08:54
Yes. I bought off a guy who swapped in 60s. He got as aftermarket axle with gearing, locker and shafts. I have the original receipt. I would say that the clutch gear is a wear item and ~8yrs is pretty good IMO. I have had it in my jeep for at least 4 yrs of that 8 and zero issues.
Old February 7th, 2020, 11:21
I suspect that it was engaged/did-engaged a lot under a load which is a no-no.
Old February 7th, 2020, 11:22
I meant to I've had mine for almost 20yrs now!
Old February 11th, 2020, 13:46
cwyman6 cwyman6 is offline
This gear is a wear item that is made of softer material. It is intended to wear out
locker popping bad - drivetrain specialist needed aparke4 South East Chapter 5 September 7th, 2008 20:57
locker popping Reichy Modified Tech Discussion 11 January 6th, 2007 07:18
locker popping aparke4 Modified Tech Discussion 12 November 10th, 2006 18:22
Popping noise in the rear kyfreeride04 Modified Tech Discussion 8 May 2nd, 2006 17:52
popping in rear end jstlink OEM Tech Discussion 0 February 16th, 2005 00:35
