Old February 5th, 2020, 12:36
4x4JeePmaNthINg's Avatar
4x4JeePmaNthINg 4x4JeePmaNthINg is online now
RE 3.5 leaf pin for shim
Starting to get some Vibes need to install shims.
I contacted Rubicon Express. They say 7/16 pin is what I need. Does this sound right, I've read different? And does anybody know if there is a torque spec for a leaf spring pin?
Old February 5th, 2020, 16:15
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Re: RE 3.5 leaf pin for shim
Why not measure the existing pins for confirmation ? All fasteners have a torque spec, you can consult your Factory Service Manual, or use the Google and torque to a Standard Steel Bolt Torque Specification.
Go ahead and slam the liftgate down on a blanket, and see how long you are laughing.
Old February 5th, 2020, 18:53
well im guessing the FSM doesnt apply to after market parts.
Is there a normal torque for the bolt/pin, or is the torque on the pin set per the application?
Ive also read the bolt should be 3/8 for my exact spring, and this has been on forums and purchase reviews... sooo Im turning to those who may have done this.
I can ballpark the bolt with a ruler, but torque would be helpful.
Old February 5th, 2020, 19:46
Anak's Avatar
Anak Anak is offline
Stranger
You can probably just get the torque spec from a table/chart for that particular bolt size/grade. It isn't going to be like a head or main cap bolt that is going into cast iron. It should be standard nut/bolt fare that you could find in an engineer's Pocket Ref.
I expect you are just looking at a cap screw. You will need to pull things apart to know for certain. Here was my experience with my OME springs: OME leaf spring fun.
Old February 9th, 2020, 20:11
shims came in, looks like they will need to be drilled to 3/8
RE shims fyi
Old February 10th, 2020, 07:06
ehall's Avatar
ehall ehall is offline
I used allen head hardened bolts from the local Ace Hardware, they work fine but you may need to drill out the perch a little bit.
my '91 beater rebuild
Old February 14th, 2020, 19:07
perch was fine, 3/8 allen bolts worked great after drilling, i think 4" lengths. It did however push the pinion closer to my TC and now the 99 front driveshaft being used with a hack n tap sye doesnt fit.
Hadnt read that consideration before but maybe this helps someone later.
Old February 16th, 2020, 06:33
Wayne Sihler's Avatar
Wayne Sihler Wayne Sihler is offline
Are you sure you got the pin in the center hole on the axle? IIRC there are 3(holes) on the pearch,but only 1 in the center.
Wayne
Member#17
NRA Life member, AARP NovaJeepers
96XJ,4.0,AW4,D30/D44,4:10s,Detroit,4.5" lift 33,s
Old February 16th, 2020, 10:34
quite certain, the center hole has to be opened up if you us RE leafs, ide already done this years ago. iirc the other holes are square.
Old February 16th, 2020, 11:15
lazyxj's Avatar
lazyxj lazyxj is offline
NAXJA Member #1310
In a pinch when needing a center pin now, and none are immediately available, take the right diameter bolt, chuck it up in a drill motor and spin the head against a spinning grinder wheel.
This changes the hex head into a round one, while reducing the head's diameter until the right size is achieved .
Both XJs are still Real XJs http://www.naxja.org/forum/showthrea...hlight=real+XJ
01 Sport, Russ Pottenger 4.6, AW4, 4" lift, 33 X 10.50 KM2, 4.56-8.25 TruTrac, D-30-E-Locker with alloy shafts, Hidden M8000 winch, Vanco front and ZJ rear disc brakes, Frame stiffeners, Lots of armor, Towing baseplate. http://www.flickr.com/photos/lwade/c...7603770130683/
1997 Country, Mostly stock, 2" lift, Engine mods, NP242, Towing baseplate
Old February 16th, 2020, 15:27
Yes, But why won't the driveshaft fit? A shim will change the angle a few degrees, but not the length.
Wayne
Member#17
Old February 16th, 2020, 20:52
well it didnt change much, but its enough that it no longer fits.
if im correct the axle moves in an arc, it will bring the pinion closer/ further from the tc output as it moves.
believe me I tried every bit of flexing/jackstand/ compression to see if it would gos in, but the angle has changed the parameters of where this arc now starts. just barley too much closer to the tc where the DS will not fit and its fully compressed. Its quite close, visually it was tempting, if the ears of the yoke were not there it may be close to seating haha.
not a chance game to play with an aluminum housed TC.
shims were 8* it may have been just enough to close this gap. when the pinion was pointed parallel to the ground, it is further from the TC. once the shims were added the shifting of the pinion has been brought ever so slightly closer. if this isnt the case i dont know how to explain it because the u bolt plates would not be sitting flat, if it was off like you asked.
Old February 17th, 2020, 10:08
The head of the center pin will fit in any of the 2 squares fore or aft of the correct center hole. Either hole could make the axle location different.
It seems that the DS was not a good length anyway,there should be more travel in a correct length DS.
Wayne
Member#17
Too much shim? spdyracer Modified Tech Discussion 13 April 11th, 2012 10:24
What is a Leaf spring shim Zuul99 Modified Tech Discussion 5 August 25th, 2010 05:53
Rear Leaf shim for the DPG SYE kit install? FastFreddy4 Modified Tech Discussion 2 August 24th, 2007 12:36
what deg. shim should i use? muddyxj84 Modified Tech Discussion 1 March 27th, 2007 12:53
HELP -- need shim kit in CO MMIXJ Modified Tech Discussion 5 May 25th, 2004 20:47
