Go Back   NAXJA Forums -::- North American XJ Association > Land Use / Off Topic and other Forums > Jeep Picture Showcase
Jeep Picture Showcase Just a place to post (show off) your Jeep or your modifications images.
Old February 15th, 2011, 08:20
gradon's Avatar
gradon gradon is offline
Cam Sprocket Mod
So my stroker made its own continuously variable valve timing via the cam sprocket half-teeth mod:
Old February 15th, 2011, 09:17
Dundy's Avatar
Dundy Dundy is offline
Re: Cam Sprocket Mod
CVE - Continuously Variable Engine
Old February 15th, 2011, 12:56
Jeepdog85's Avatar
Jeepdog85 Jeepdog85 is offline
That's bad.........yup .... That's bad
Old February 15th, 2011, 14:15
Muad'Dib's Avatar
Muad'Dib Muad'Dib is offline
Thanks for the tip.. GREAT MOD!! Id recommend this to anyone!
Old February 15th, 2011, 14:29
JohnX's Avatar
JohnX JohnX is offline
Sarge <3 Ben
Bummer, time for a rebuild.
Praise Marty Moose!
Old February 15th, 2011, 17:59
gradon's Avatar
It was running great when it left me stranded(no hints of this happening before). No rebuild--I'm just gonna drop the pan, make sure the oil pump screen is good and all the metal is out and throw a new dual roller timing set on. The cam and crank spin freely. After a bit of research, it seems that single rollers don't like the added pressure from the bigger springs. Anyhow, 2.5 years and 35K before a "major" issue is fine in my book for a first engine build(can't count the typical xj issues). It takes all the abuse I throw its way and if some part can't take it, then it's got to go.
Old February 15th, 2011, 18:41
JohnX's Avatar
Sarge <3 Ben
Really?? You may want to consider at least a tear down and cleanout with new bearings. All that metal is IN your motor. My guess is another major issue soon....like rods knocking
Praise Marty Moose!
Rate This Thread:
Hole Behind Timing Sprocket scca28 OEM Tech Discussion 2 May 6th, 2007 22:02
The Saga of the stranded Sprocket head. DrMoab Moab Fall Fling, October 2006 24 November 1st, 2006 20:40
Stock drive sprocket for NP231 lilredwagn Wanted: Private Party Only 1 June 7th, 2006 18:05
NP231HD sprocket and chain in a NP231? lazyxj Modified Tech Discussion 6 August 26th, 2004 06:18
