Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Chapters > SoCal Chapter > Arizona For Sale/Wanted
Arizona For Sale/Wanted For Sale/Wanted for Arizona.
Old August 26th, 2018, 19:46
redneck redneck is offline
1998 XJ 4.0L, AX15, NP231, D44/D44
1998 Jeep Cherokee XJ "Rubicon" 4.0L inline 6, AX15 manual transmission, NP231 transfercase, Built Jeep TJ Rubicon Dana 44 axles, manual door locks, manual windows, cruise control. Arizona Jeep its entire life, bought from Bill Luke Chrysler Jeep in 1998. I am the second owner and got it from a longtime family friend that used it as a commuter and had only engaged the 4wd a hand full of times on dirt roads. I have done all the modifications myself from bone stock when I got it.
This has been my daily driver for over 5 years now and it has never let me down. When I got the jeep I replaced the entire cooling system and charging system and steering components (including pump and hoses) with new NAPA parts. I replaced all of the clutch components and installed a new Crankshaft Position Sensor while I was there. I built this XJ as a daily driver/weekend warrior with all the good stuff so I wouldn't have to worry. I used this Jeep as a commuter to West Texas last summer without hesitation or issue. It is the most fuel efficient (17-18 mpg) and happy driving down the highway at 70mph with the cruise control on and the AC blowing.
This is the 3rd Cherokee XJ that I built and intended for it to be my last. I am only selling because I am stepping up to a JK for more space.
With that being said, I am including all of my XJ spare parts in this sale. This includes but is not limited to; lights, axle shafts, hardware, fender flares, u-joints, relays, hub bearings, alternator, power steering pump, hoses, sensors, etc... Most everything is in boxes or plastic totes. Do with it what you want but, it comes with the Jeep!
Please understand that this is a 20 years old XJ that has been used off-road but, not abused. I know that I am forgetting some of the things about it so just call or email me with questions. Asking $8500 or best offer. Please, be reasonable with the offers and do not waste my time with low ball offers. If you are a Jeep or XJ guy, you know how much this build took. I am willing to deliver to the states surrounding AZ for the cost of fuel.
602- zeven9nine- ten eightyseven.
1998 Jeep XJ Cherokee 4.0L, AX15, NP231, D44/D44, 196K miles
AXLES
FRONT TJ Rubicon D44
Yukon Zip air locker
Yukon 4.10 gears
Yukon chromo shafts
Solid Axle Industries diff cover
Timkin Bearing and seals
Timkin Hub bearings
Centric Parts 120.67045 Premium Brake Rotors
EBC Brakes Yellowstuff brake pads
Iron Rock Off Road axle tube Sleeve kit
Gusseted UCA bracket
" plate skids on LCA brackets
MOOG V8 ZJ Steering
Old Man Emu steering stabilizer
Braded Stainless Steel extended brake lines
REAR TJ Rubicon D44
Stock Rubicon 4.10 gears and locker w/LSD
Yukon chromo shafts
Serious Offroad axle truss
Ruffstuff D44 axle swap brackets
High clearance shock mounts
SUSPENSION
Old Man Emu 3" coil springs
Old Man Emu 2.5" Dakar Leafs
JKS boomerang shackle
Rustys off road lower and upper adjustable control arms
JKS track bar
JKS quick disconnects
Old Man Emu Nitrogen Sport shocks
TAD drive shafts (Deer Valley local) with 1310 to 1330 conversion joints
Advance adapters SYE
31x10.50-15 BFG KM2 w/ Discount Tire certs
Spidertrax 1.25" wheel spacers for stock silver Ecco aluminum rims
Engine
99+ intake
Jeepers Creepers 62mm throttle body
AFE intake
Ford Fuel Injectors
APN Header
2.5" custom down pipe
Magnaflow Muffler - Nice and mild with no cabin drone on the highway
Brown Dog engine mount plates and mounts
New clutch and all components about 25K miles ago
Armor
JCR Deluxe front bumper with hoop and Unibody Tie-in Kit w/Steering Spacer
Plate cross member behind front bumper holding winch under radiator
JCR Gen 1 Crusader rear bumper with unibody tie-in bracket and integrated lower quarter panel armor.
JCR Crusader rock sliders
JCR transfer case skid
JCR Gas tank skid
Rusty's Off-road engine/transmission skid plate (not installed)
Other
Rugged Ridge Heavy Duty 8500lbs winch
Smittybilt 2810 Low Profile Roller Fairlead
ARB on board air with 1.5 gallon tank
European export tail lights (have stock as well)
Rigid Industries 30" combo light bar
Rigid Industries Dually Series Flood cubes
5-90 Battery cable upgrade
ScanGauge next to A-pillar
Truck-lite knock off LED head lights
Alpine CDE-HD148BT CD Receiver
Infinity Reference 6032cf 6.5-Inch Speakers
Polk Audio AA3085-A MM840 DVC 8-Inch Subwoofer
Subthump Cargo Stealth Enclosure
Alpine MRV-M500 Mono V-Power Digital Amplifier
FireStik FL3-B Three Foot FireFly Antenna
FireStik MK-174 Hood Channel Mount
Uniden PRO520XL CB Radio
Prime 4x4 Illuminated Rocker Switch Panel with labeled switches
Lund Catch-All Front Floor Liners, 2nd Seat Floor Liner, and Rear Cargo Liner
Boostwerks Engineering 231 HD Shift Linkage (still in box)
Old August 27th, 2018, 17:34
Re: 1998 XJ 4.0L, AX15, NP231, D44/D44
Tires rotated and balanced today, ready for a new home. Make offer!
Old August 29th, 2018, 20:46
BlurpleXJ's Avatar
BlurpleXJ BlurpleXJ is offline
Blue. Purple. Blurple.
Looks like a great setup. If I had room for another jeep I would snap this up.
1998 XJ "Roxanne" AKA "The Blurple": Stroked Jeep playing expedition rig
2007 Triumph Bonneville: last of the carbies
1976 BMW R90/6
Old August 30th, 2018, 12:27
SOLD!!!
Rate This Thread:
1998 XJ 4.0L, AX15, NP231, D44/D44, Arizona redneck SoCal For Sale 4 August 30th, 2018 12:27
1998 AW4 2WD to 1991 AX15 4WD Swap yellowoctupus Modified Tech Discussion 5 June 4th, 2017 23:23
93 xj 4.0 ax15 np231 Reichy MWC For Sale/Wanted Forum 4 June 23rd, 2014 14:03
np231 swap from 1998 aw4 to a 1992 ax15 wayne2300 OEM Tech Discussion 4 September 1st, 2010 15:33
AX15 & NP231 Gjeep Modified Tech Discussion 5 March 20th, 2010 23:45
