1996 XJ Expedition Rig
cpolish24
Arizona
1996 JEEP Cherokee Country
4.0 HO 6 - Cylinder Automatic
135,500
- PSC Power Steering - Ice Cold A/C
- Power Seats - Power Windows
- Tinted Windows - Serviced Regularly!
--2010 SEMA Show Jeep--​
Suspension & Steering
Front
- Custom Fabricated 6” Tri-Link Long Travel Lift -
- RK 2” Solid Stock Long Arms w/ Monster Flex Joints -
- 2.0 EiBach Dual Rate Coil Springs -
- 12” 2.0 Fox Racing Shox Remote Reservoir Coilovers -
- Custom HD Track Bar with HD Track Bar Brackets and ¾” Heims -
- Currie AntiRock Sway Bar w/ Custom Heim End Links -
- RK 1.5” Solid Stock Chromo Steering Center Link w/ O.E. TRE’s -
- PSC Complete Hydro-assist RAM System w/ Aluminum Cooler -
Rear
- Custom Fabricated 4-Link Long Travel Lift -
- RK 2” Solid Stock Long Arms w/ Chromo Monster Flex Joints -
- 4” HD Dual Rate TJ Rear Coil Springs -
- 12” 2.0 Fox Racing Shox Remote Reservoir Shocks -
Drivetrain
Front
- Dynatrac ProRock 44 JK Rubicon Axle Housing (Royal Purple Fluid ONLY) -
- Rubicon E-Lock Electric Locker -
- 5.38 Superior Ring & Pinon -
- 30 Spline Superior 44 Chromo Evolution Axle Shafts -
- CTM Racing U-Joints -
- Spyntec Front Hub Conversion w/ 30 Spline Warn Locking Hubs -
- REID Racing JK Rubicon Forged Steering Knuckles -
- EBC Disk Brake Upgrade -
Rear
- JK Dana 44 Axle Housing w/ RK HD Welded Truss System (Royal Purple Fluid ONLY) -
- Dynatrac Pro 44 Differential Cover -
- ARB Air Locker -
Transfer Case & Driveline
- Tom Woods 1310 Dual Double Cardin Front Drive Shaft -
- Tom Woods 1350 Double Cardin Rear Drive Shaft w/ Flange Yokes -
- Advanced Adapters 4.3:1 Atlas II 2-Speed Transfer Case (AMSOIL Synthetic Fluid) -
- 12x6” External Transmission Cooler -
Engine
- Brown Dog Motor Mounts w/ HD Engine Mounting Brackets -
- Large K&N Air Filter -
- Helix Throttle Body Spacer -
- MSD Ignition Wires -
- Accel Ignition Coil -
- Boss 220Amp. Alternetor -
- Optima Yellow Top Battery -
- High Flow Water Pump -
- Borla Stainless Race Header -
- Spintec Exhaust Muffler & High Flow Catalytic Converter System (Incredible Smooth Sound) -
- Custom Fab Exhaust Down Pipe -
Accessories
- 5 - 37 x 12.50 R17 Goodyear MT/R’s Kevlar -
- 5 - 17x9.5” Raceline Monster Beadlock 5x5.5 Wheels -
- OR-Fab Custom Front Winch Bumper w/Grill Hoop and Light Bracket -
- OR-Fab Custom Rock Rails -
- OR-Fab Custom Rear Bumper w/LED Center Light -
- OR-Fab Custom Rear Quarter Armor w/Rail Bar -
- OR-Fab Custom Front Tube Fenders -
- JKS HD Transmission Cross Member -
- Warn 8000lb Winch -
- Master Pull Superline XD Synthetic Winch Line (5/16” x 100’- 21,000lb) -
- Master Pull Billet Haws Fairlead -
- Gobi USA Full Roof Rack w/ Latter & Hi-Lift Mount -
- 48” Extreme Hi-Lift Jack -
- 6000K HID Head Lights w/ DOT Diamond Cut Glass Housing -
- 4 KC 6x9 50watt HID’s Long Range Lights -
- 2 KC 4x6 100watt Long Range Lights -
- 2 KC 2x6 55watt Flood Lights -
- 2 KC 3x5 100watt Wide Beam Lights -
- Z-34 Turbo Hood Vents -
- Sony Xplod CD Player w/ IPod Plug-in -
- 4 - 5.25”Alpine SPR-13S 300W Component Speakers -
- Cobra Handheld 75W CB Radio w/ 2Ft. Fire Stick -
- ARB Air Locker Compressor -
- ViAir X’treme Duty On-Board Air System for 37” Tires & 2-2gal Tanks -
- Grand Cherokee Plush Seat -
- 2” Receiver Tow Hitch -​
What I have listed here is the round about cost of each item. I have almost $40,000 invested in all of the accessory items installed on this Cherokee. Mind you that this cost does not include the $15K-20K spent on labor, servicing, maintaining, sheet metal, and custom fabrication involved in building this rig. I'm sure that I'm into this Cherokee nearly $60K Total. No expense was spared in building this unique XJ.
This Cherokee is one of the last manufactured square body XJ prier to the Cherokee going to the new "rounder" body style. This XJ is in great shape for its age, very well taken care of and extremely reliable. The motor runs very strong as well as everything else on the Cherokee. It will take you anywhere you want to go. I drive this Jeep regularly to work (on the Hwy), it drives very smooth down any road.
This Cherokee was one of the runners-up for SEMA's "2010 Hottest 4x4 of the Show" in Nov. Since SEMA, the Jeep has been in storage, waiting to attend the next events. It's one of the cleanest Cherokee's in the USA!
I truly have NO real need to sell my beloved Cherokee, but it's a new year and I would like to start a new project.
Asking.......$20K obo
Thanks for looking guys
Here are a few from BB trip...these are a little older, I have some at work of the last rubicon trip not long ago...then the Jeep had some more upgrades (fenders, hub conversion, reid knuckles) and a new set of wheels(bolt pattern change) to get it ready for sema..
