redneck
- Prescott/Phoenix AZ
Well… Its time… With my work schedule overseas my time to go out and enjoy the Jeep has been cut down to almost nothing. I really hate to do this but she’s got to go… The final stage of the build happened in the middle of 2010 and I have only taken it out wheeling once. I have yet to get time to even get the little bugs worked out. It was rebuilt with good quality parts and has less than 1200 miles on everything. The odometer reads around 170K miles but that’s just the body. I have receipts for most things on it. Freshly built stroker, brand new AW4, new Atlas, freshly built/rebuilt axles, new drive shafts. Tires have about 4000 miles on them. Exo cage can be cut at the bottom and lifted off the XJ as one unit.
There are only a few things that need to be addressed on it.
• The rear needs bump stops.
• Front ACOS bump stops need to be adjusted
• The front limiting straps are too long.
• Engine still needs to be tuned. It’s a 4.7L stroker with extensive head work. It needs larger injectors; I know that since it’s got new stock ones on it and running lean. I have new larger injectors on the way.
• I have also been fighting with the engine temp but believe it to be a bad temp sensor + lean condition.
• Front output on the Atlas will not going into 4H, linkage needs to be adjusted
Again, I have had little time with it to actually get it all worked out since the rebuild due to my work rotation overseas.
I’m looking to sell it all together, not part out. I am losing the place where I store it and it needs to find a new home. I really hate to get rid of it after investing so much into it but it makes no sense to keep it. I am currently out of country but am able to answer any questions you may have. I will be back in Phoenix in mid-February. I am looking to get $22,000 but am open to offers and potentially some trades plus cash. I have way more than that invested into her than I’m asking (doesn’t everyone?). I know its an XJ but there are a ton of parts on this thing. Possibly interested in a double bay tool box or larger, various shop tools (floor drill press, press, brake, air compressor, Etc…), or utility ATV/side by side as part trade.
Here's what she’s got… I’m sure I’m forgetting a few things. It’s been a while since it was built.
Axles
Front Currie Dana 44
• 4.56 G2 gears
• WJ knuckles
• Gusseted knuckles
• RCV shafts
• ARB locker
• ARB diff cover
Rear XJ Dana 44
• 4.56 G2 gears
• Tube truss
• Superior Jeep Super 44 Rear Axle Kits, 33 Spline
• 33 spline ARB locker
• Solid diff cover
• Teraflex disk conversion
Steering
• PSC hydraulic assist
• 1.25x.25 DOM tube with heims
• MORE steering box brace
• JCR steering box spacer
Driveline
• Atlas II 4.3 transfer case
• New AW4
• 315/75-16 BFG KM2’s
• TJ Rubicon MOAB rims
Suspension
Front
• Rusty’s long arms
• Rusty’s 4.5” coils
• JKS ACOS Pro
• Rancho RS9000 shocks (have a set of Bilstein 5150’s)
• Modified Rubicon Express track bar bracket
• Rubicon Express track bar bracket brace
• 1.25x.25 DOM tube Track bar with heims
• Currie Antirock
Rear
• Clayton Off Road 4.5” leafs
• H.D. Off-Road Engineering Shackle relocation brackets
• Rubicon Express Boomerang Shackles
• Rubicon Express monotube shocks
• Upper shock hoop (mounted under floor)
• Synergy Suspension Rear Spring Hanger Bracket
Body
• H.D Off-Road Engineering full set of unibody stiffeners
• Raptor lined under body
• JCR Off Road winch bumper
• JCR Off Road stage 2 sliders
• Custom rear bumper
• Full Exocage
• Swing away tire carrier built onto cage
• All external armor power coated
• Rusty’s gas tank skid
• Rusty’s transfer case skid
• Rusty’s engine skid
• Interior cage
• 4 point harnesses front and rear
• 2001 limited leather interior
• Overhead console with trans temp, air tank pressure, and all switches
• VIAIR Ultra Duty Onboard Air System
• Warn 9.5xp with Warn remote (winch installed but not hooked up, never used)
• ORO LITESPOTZ rock light kit
Engine
• 4.7L Stroker (all new everything, accessories, sensors, etc…)
• Roller rockers
• Port and polished head
• Port matched 99’ intake
• Bored throttle body
• THOR intake
• Brown Dog Engine mounts and engine plats
• CSF 3 core radiator
• Dirtbound Off Road electric fan setup
• Ceramic coated Banks header
• Flowmaster 50
Light bar not included...
Axles
• 4.56 G2 gears
• WJ knuckles
• Gusseted knuckles
• RCV shafts
• ARB locker
• ARB diff cover
Rear XJ Dana 44
• 4.56 G2 gears
• Tube truss
• Solid diff cover
Steering
Driveline
• New AW4
Suspension
Front
• Rusty’s long arms
• JKS ACOS Pro
• Currie Antirock
Rear
Body
• Full Exocage
• Interior cage
Engine
• Roller rockers
• THOR intake
• Flowmaster 50
