Monster3663
- Placitas, NM
So I started the swap by completely stripping out my 1990 XJ. Engine, 5 speed transmission, transfer case, all wiring . So far these are the differences found after stripping out the 98. I was going to start this thread when I completed it but it’s a lot of stuff.
1. All the electrical connectors are different.
2. The dash is mounted different. (You will have to remove brackets off of the donor XJ).
3. The steering column is different and mounted with an aluminum bracket which is secured to the brake pedal bracket and the left side inner firewall where the fuse used to be.
4. There are several different cutouts on firewall that changed between the years.
a. Main harness cutout is round on 98 and square on 90.
b. Needed new cutout for harness that goes to fuse box.
c. Needed new cutout for Automatic linkage to transmission.
d. Needed new cutout to relocate the antenna due to fuse block being in the way of old one.
e. Cut out for the steering out of the cab mount different and the hole is oblong and needs to be round.
5. The fuse box is on the passenger side.
6. The electrical going to the fuel tank has four wires and the 90 XJ had only three. (So I'm changing fuel tank out too)
7. The center console is different along with the dents in the hump. I still haven't messed with that much. I will be writing more about that when I get to it.
8. The old brackets on 90 XJ that hold steering wheel and heater up have to be removed.
9. All but one of the heater bolts line up. I will have to drill out one location. The cutout where the A/C and the heater core come through fire wall is smaller on the 98. I filled it with sealer.
10. The headliner fit just had to move a bracket from the donor to the 90 that holds the interior light in place. Fastened with sheet metal screws.
11. The wiring harness from front to rear is split and goes on both sides not just the drivers side like the 90.
12. The e-brake handle is different but still fits in the cutout that is there. One bolt will fit hole it in place and then I had to Fab a piece from donor and used a self tapper on last one.
13. Charcoal canister is in the back under XJ and not in engine compartment like the 90.
Donor 1998 XJ
Recipient 1990 XJ 5 speed
Donor 1998 XJ
