ANY MPG READERS FOR THE OBD1 JEEPS? OR CAN INTALL OLD MPG READ OUTS FROM OTHER JEEPS?
I would guess this would require installing an engine computer from a 92 Plymouth. :}
I'd like to see a write-up on that mod :laugh3:
i have one in my 86 300zx and it takes the load of the engine. injector pulse duration. and i believe readings from the 02 sensor.
this is a factory option in it. so it came with it.
Do you have a digital dash on your Z31? I had an analog on my '85 and dont remember anything like that, its been a while since I've owned it.
The unit out of the Voyager will work if you can get the caps lock to turn off when you install it.
