Stumped
pwt87mj
Albany OR
I did the peugeot to ax15 swap, and now when i drive my jeep the transmission makes a funny noise when in gear like it has no fluid in the tranny, but it does, it does it realy bad when i turn, like somethings binding up or something, but not when its in neutral, its really hard to describe. Any thoughts would be greaaaatly appreciated!
Clutch pedal in or out, or both?
Did you put fluid in the transfer case?
What type of lube did you use in the transmission and transfer case?
Maybe an exhaust grind/rattle against something?
