While driving my oil pump drive shaft must have run low on oil (?) and got hot enough to melt the camshaft position sensor of course the engine would not run. When I replaced the oil pump drive and sensor I found three teeth broken off of oil pump shaft gear. The shaft was frozen in the pump drive assembly.
I removed the pan and looked at camshaft gear which was okay I also found the three teeth.
The XJ has 36,000 miles.
How common is this? Thanks
