Old November 10th, 2018, 07:36
Sweet700 Sweet700 is offline
92 xj major running issues
Started as a intermittant sputter and popping between 2- 3000rpm and would run perfect after 3000 rpm.
Progressed to no power to move itself while this is happening.
If i put it into 4 low it will drive fine up to 2000rpm an gets me home.
Last night it got much worse. Started stalling, sometimes it would start with really low idle but no power to move.
Just changed oxy sensor, plugs, wires, cap and button, radiator, gas filter. No changes.
Please help
Old November 10th, 2018, 07:39
Re: 92 xj major running issues
Seems to begin as a hesitation with quick throttle movements and i can baby it through that and go on.
Then the hesitation gets worse to the point of no start. Seems to improve after sitting
Old November 10th, 2018, 08:58
Trying hard to not start throwing parts at it.
I have a fuel pump ordered, had a low reading of 25psi yesterday.
When it's having the issue though there is a strong odor of gas from the exhaust which has me thinking electrical.
Almost ready to just go buy tps, cps, water temp, coil, map
Old November 10th, 2018, 10:10
sidewaysstarion's Avatar
sidewaysstarion sidewaysstarion is offline
Coffee Drinker
If you're fuel pressure is 25 psi, that would cause the lean pops you're hearing and definitely make it run poor. Have you checked the fuel pressure regulator?
Originally Posted by cracker
I seem to have run out of self tapping washers
99 4.0/AW4/231, with a few basic bolt ons.
Click here to support
Old November 10th, 2018, 12:49
lawsoncl lawsoncl is offline
If you're going to start buying things, consider buying a decent meter and test what you've got. The TPS and temp sensors are easy to test. TPS sensor would be the first thing I'd test. Check grounds, etc.
Old November 10th, 2018, 18:50
Haven't check the pressure regulator yet other than pulling the vacuum off of it while assessing fuel pressure. Pressure didn't change.
The tps tested good when i checked it but the problem seems the worst when the jeep gets hot from use, not from idling in the shop. I haven't been near home when the jeep is really acting up.
Old November 10th, 2018, 19:57
blu3fan's Avatar
blu3fan blu3fan is offline
Crankshaft position sensor.
Or its the dreaded Fuel pump ballast.
If you have the fuel pump ballast. its under the dash drivers side. little white looking thing
connect the two wires.
Throw that piece of trash into the street and drive over it a few times.
Old November 10th, 2018, 20:00
blu3fan's Avatar
Actually I want to add to that.
After driving over it.
Smash that thing to smithereens and curse the Idiot who decided the fuel pump was *Too Loud*
Old November 10th, 2018, 20:23
I have unplugged the ballast and it has an effect on the idle so i plugged it back in.
I'll try joining the wires with a double female and see how that works.
I had read that crank position sensor would be a no start when it failed but not much about spitting, sputtering, backfiring through intake, no power and strong gas odor.
Old November 11th, 2018, 16:29
trippled trippled is offline
Address the low fuel pressure and go from there. Crank sensor can have a good read at low engine speeds but break up at higher rpms cauing running issues but can really only be tested with a scope or by replacement.
Old November 11th, 2018, 16:42
blu3fan's Avatar
I would suggest installing a fuel gauge if you are not sure if you have fuel issues.
you should be 35+ running.
https://www.cherokeeforum.com/f30/pe...-gauge-185916/
I put this on years ago to mine.
It takes a lot of the headache out of troubleshooting.
Old November 12th, 2018, 13:04
Just had my low fuel pressure verified by a second gauge.
Turning the key without starting i got 8psi first turn, 15psi second turn, 20psi third turn.
Started it and got 20psi.
Crawled underneath, pinched the return line and got no change, stayed at 20psi.
Pulled the vacuum from the regulator and no change.
Bypassed the ballast regulator and got a 5psi increase to 25psi.
Seems to be damning for the pump.
I
On another note, i showed my dad the old gas filter and he noticed that something was loose inside. i took the old gas filter apart with a hacksaw and the element was loose and therefore not filtering anything.
Hope it doesn't come back to haunt me.
Thanks for the help and suggestions up to this point.
Now i wait for my new Bosch fuel pump.
O2 Sensor Heater Wiring - Major Issues Miller88 OEM Tech Discussion 2 August 24th, 2016 11:47
Please help, major locker issues. FleXJ96 Modified Tech Discussion 14 October 9th, 2012 13:16
Dust Junies Racing overcomes major issues at the Freedom 250 Loose_Nuts_Enterprises SoCal Chapter 4 July 24th, 2008 14:27
4.0 Running issues JT_Law OEM Tech Discussion 8 September 10th, 2006 23:45
