jmckennan
- Lake Mathews, CA.
Ok so my daughter comes to me a few weeks ago says headlights dont work, no problem put in new switch, they work great for a week or so. She now tells me they turn on and off consistantly while they are on, ok put new switch in, but this time if you pull to parking light position nothing works, if you pull knob just slightly past PL position they come on and warning buzzer as well (when door open, if you pull knob all the way to headlight on position they work but no parking lights, if you push knob back just before the knob clicks into headlights on position everything works or pulling knob right before headlight on position everything works. Now heres the thing, at first I thought ok I got a bad switch, 3 switches later including a OEM from Chrysler I get the same results. All fuses are good I'm getting a good ground, I checked connector undernieth air filter box, wires going into switch connector at dash arent not burnt or damaged, I'm just losing that power at PL position and PL and HL when they both should be on when knob is pulled all the way out. I'm baffled, any ideas would be great. I need to get this fixed as it needs to pass a state inspection to get registered (21 year old girl in her brand new BMW doing 80 hydroplaned and hit my daughter, insurance payed daughter off but now has salvage title only damage to Jeep was front right fender but needs to pass inspection to register)
