climbtothebeet
- oklahoma
ive got a 2000 cherokee with the 4.0 and auto trans. The jeep died while driving, and i had it towed home. When you turn the key on the fuel pump runs for a few seconds, but quits. If i hold open the scrader(sp) valve while cranking it only pumps fora few seconds then stops. I replaced the pump and filters and still have the same problem. what could it be? The jeep will start off of ether but will die when it burns up all of the ether, so it has spark. is there some sensor that could be causing this?
