Old August 6th, 2009, 16:07
JeepsterXJ JeepsterXJ is offline
2000 XJ - stalling issue
My battery died while I was putting in a new trackbar. Charged it up a little, and went to start it. Strong cranking, but no start. Took me giving it some gas to get it to fire.
It idles fine now - unless you are at 0mph. You can be going along at 1mph, but once you come to a complete stop, it goes down to 200rpm and will eventually stall.
I have another 2000XJ I can swap parts from, but don't want to do it blind if you guys have an idea on what I should zero in on.
Old August 6th, 2009, 16:12
jneary's Avatar
jneary jneary is offline
Re: 2000 XJ - stalling issue
sounds like the pcm lost its memory from the dead battery. just statr it and keep it running, slowly decreasing the idle ant it should relearn
Old August 6th, 2009, 16:14
Alright, and if I sound all antsy about a simple problem, its because I'm going to drive this 5 hours tomorrow in this is bad timing for an issue!
Old August 6th, 2009, 16:19
jneary's Avatar
it should be ok, if it was fine before the battery was replaced
Old August 6th, 2009, 16:35
Thanks jneary. I put my spare ECU from off the shelf. No issue (except the CEL turned on, I assume from the foreign computer). Put in old computer. Light goes out, idles, take a test drive, all fine. Thing was just messing with me I guess.
Old August 6th, 2009, 20:24
bmfm64 bmfm64 is offline
put a full charge on the battery... low battery messes with sensors and such.
Old August 9th, 2009, 10:07
birchlakeXJ's Avatar
birchlakeXJ birchlakeXJ is offline
What you describe could easily be a marginal battery. Have it load tested. It's the only conclusive way to deteremine battery condition.
Stalling issue? The Lure Washer OEM Tech Discussion 3 February 18th, 2009 11:07
2000 XJ stalling, shifting irregularly LiamN OEM Tech Discussion 10 January 6th, 2008 11:06
yet another renix stalling issue (this one more complicated) tealcherokee Modified Tech Discussion 21 May 19th, 2006 21:48
Stalling issue when idiling daddyphatsacs OEM Tech Discussion 6 May 16th, 2006 22:26
XJ stalling issue LAcherokee OEM Tech Discussion 6 May 2nd, 2006 20:59
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
