Prev Previous Post   Next Post Next
Old February 9th, 2014, 03:28
a_ibrahem a_ibrahem is offline
2000 XJ TPS issue
Hello everybody ,
am new here to the forum and to the XJ also ,
i have 2000 I6 AT XJ ,
it has P0123 code ,
my XJ has one socket to the TPS with 3 wires
as i understand the wires are :
1- TPS ground
2- TPS signal to PCM
3- 5 volts from PCM
i unpluged the connector to the TPS sensor and measured with the fluke while ignetion key in ON position
i have 5 volts on wire 2 and 3
my question : wire 2 is signal from TPS to PCM so why there is 5V on the wire all time ??
please advise.
2000 xj Window Issue Trixie03 OEM Tech Discussion 13 April 22nd, 2013 11:22
2000 Xj classic 4x4 shifting issue seanjohn0226 OEM Tech Discussion 3 January 16th, 2013 18:19
2000 xj fuel issue climbtothebeet OEM Tech Discussion 3 September 20th, 2009 06:43
2000 XJ - stalling issue JeepsterXJ OEM Tech Discussion 6 August 9th, 2009 10:07
2000 XJ D-35 w/ABS Rear End Issue aviationstation OEM Tech Discussion 2 March 31st, 2005 17:23
