artyart
- Pawling NY
After 12 years of good service to me, times have changed and Ihave to move on. So I am seling my XJ..... 1996 (SE model) setup for "moderate 4 wheeling" It has......
Sunroof
All manual windows and doors.
(Rear doors only open from inside)
Stripped interior, no rear seat
Fender wells and rear modded to fit larger tires
Fuel tank is lifted up between rear frame rails, encased in a steel box in cargo area, has a custom rack
as a cover.
3" RE Lift (full spring packs in rear)
1" RE shackles in rear.
Backup lights mounted in rear hatch,
Rusty's taillight housings, with lights and harness,
RE upper and lower adjustable control arms
RE Hd Tie rod
RE "1600" track bar
More Steering box brace
JKS Quick disconnects
Superior front axle seals
4.0 engine , has Mean Green hd alternator,
rock-it thermostat housing.
recently replaced exhaust manifold,
2 row modine all metal hd radiator
Vented hood
Modified airbox with K&N Flat filter
AW4 Transmission with 12,000 lb truck aux trans cooler
Corp 8.25 axle (29spine) with 2 sets of spare shafts, spider gears etc.
D-30 front with spare shafts , 2 sets of spare unit bearings /stub shafts.
Current unit bearings are 3 yrs old with lo miles. (Timken)
3.55 gearing
ZJ disk conversion on rear with ZJ prop valve,
24" Stainless rear brake line
YJ front Brake lines
Hard Brake lines replaced with excption of driver side front
Atlas 3.8:1 twin stick transfer case
Tom Woods Drive shafts
Custom 4x4 Rock Rails
Custom 4x4 Tow hook brackets with shackle adapters
4x Doctor 8.25 diff guard
Custom 4x4 d30 diff guard
Skid Row Engine/Transmission Skid
Skid Row Transfer Case Skid
Skid Row Front lower ctrl arm skids
Hidden hitch rear hitch.
Bilstein 5100 shocks
4 33x12.5 BFG muds mounted on aluminu AR style wheels, about 85%
tread, two unmounted spares at about 40-50% tread
Passed NYS Inspection Jan 2012.
Comes with several large boxes of spare parts, some used some new,
Highlights are.... spare alternator,master cylinder,steering box,brake booster aw4 transmission pump,brake lines,sensors, ujoints (297 style and 1310 style), Differential parts and some covers,yokes, several boxes of nuts and bolts.
Located in Pawling NY $3500 buys it and all the spare parts you can stuff into it.
Sunroof
as a cover.
RE Hd Tie rod
RE "1600" track bar
Vented hood
3.55 gearing
