Thought I'd give an update. I did a compression test today. Engine had been driven about 3 hours before, so it was getting cool. My numbers were...
123
115
123
120
127
123
Pretty consistent, but they seem a bit on the low side.
I then took off the cap to inspect it and notice that I could wiggle the rotor shaft around by hand, and the button was scored a bit. I think that might be the cause of my intermittent miss so I'll try replacing the distributor.
Question though: based on those compression numbers, is the engine getting pretty tired to keep fixing, or does it have a lot of life left? I might test the number one cylinder hot this week and see how much higher it goes, then up all my numbers by that percent.
123
115
123
120
127
123
