XJBeater
- Lewiston, Maine
I just finished up an s10 bastard lift in the rear using just the 2 middle leafs and also put in some ford springs in the front. I also dropped the transfer case an inch. The problem I have is that I have 4lo, fulltime, but when put into 4 lo it will not engage. I can hear the transfer case grinding like it is half engaged. It all worked fine before the lift. Do I need to lower the case more? I figured that an inch for 3 inches of lift would be fine.
