Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Unibody Jeep Technical Forums > Jeep Cherokee XJ (1984 - 2001) > Modified Tech Discussion > Paint and Bodywork forum
Paint and Bodywork forum Around here sheetmetal is optional but if you are going to do it, do it right.
Old October 31st, 2017, 12:43
sinat01's Avatar
sinat01 sinat01 is offline
Rust Repair/ body mods help
Ill try to upload pics when I get home but here is what im dealing with.
1999 2 Door Cherokee
built rock rails in place of the rocker panels.
I want to do the cut n fold, buut instead of folding whats left of the rusty metal. I want to cut it off and make a plate to go in there. Has anyone done this instead? and if so, how heavy of a steel did you use?
the other issue I have is the door hinge pins are worn (again) the bottom hinge is ovaled out, and I have the typical cracks around the vent in the door frame. I want to get the braces that weld in, and figure since im doing one, I might as well do the one to brace the hinges also.
Could I drill the ovaled out hole back to round, and size up a bronze bushing to go in the whole and use a bolt or pin to keep the door where it needs to be?
Old February 27th, 2018, 10:45
97sport's Avatar
97sport 97sport is offline
Re: Rust Repair/ body mods help
I did the cut and fold with separate piece of standard sheet metal (16 Gauge i think) been 4 years in Canada with no issues. As for your door hinges ive never heard of anyone doing this but sounds like it will work with enough time put in. Im guessing you dont want to cut the old hinges off the body and weld new ones on?
Old February 27th, 2018, 11:07
sinat01's Avatar
If I cut the hinges to put new ones in, id prolly do the old style hinges so I could make the door removable. and I got cut and fold panels from the flop shop offroad.
Old April 25th, 2018, 14:17
sinat01's Avatar
not quite related to my original subject, but if I wanted to do some paint repair with the spray touch up paint, whats a good way to go about it? wet sand it then paint it? there are two areas that I need to take to bare metal, so primer, wet sand, paint, then clear coat?
Old April 26th, 2018, 08:47
smokeyyank's Avatar
smokeyyank smokeyyank is offline
Jeepoholic
Should be; take to metal, fill with bondo if needed (any body damage you should use a base to build it up slightly, glaze coat, primer, base coat, clear coat, wet sand. Wet sand is mainly to clear imperfections in the clear coat. You can do on base coat if you get runs but that would really be about it.
To answer your original questions. You probably want a 16-18 gauge steel IIRC. Then spot weld it into place, use body sealant/seam sealer to seal it up. Don't run full welds, no need to and it could possibly warp the metal.
For your door if you're talking about this
Could either do what you're saying or get a bigger bolt and use washer.
You can also use this if you want to reinforce it.
https://www.hooliganoffroad.com/prod...-hinge-support
another rust repair rastein77 Modified Tech Discussion 11 February 23rd, 2014 09:01
Body shop for rust repair in NoVA? N8N_99xj South East Chapter 1 March 28th, 2013 10:47
Rust Repair. tcpoland Colorado Chapter 0 April 7th, 2012 13:14
Rust repair... DutchVDub Colorado Chapter 6 May 29th, 2008 19:57
95-xj-rust repair 95xjpa OEM Tech Discussion 3 March 29th, 2005 06:18
