Avanteone
- Auburn, WA
I consider myself (and my tech's) to be pretty good, but this one has us stumped.
1991 XJ 4.0/auto. A little history. The engine was replaced. One guy removed and disassembled, and basically set the re-man long block in place, then bailed. The rest of it was re-assembled by several backyard mechanic types, so who knows where the problem could be. It did run before the engine replacement. We found the main engine to body ground missing, and replaced it. The ground wires on pass. side of block were bolted to valve cover instead of the block, so we fixed those. We have good compression, meaning the timing chain was installed correctly. We have spark, we have correct fuel pressure to rail, we have injector pulse (noid) while cranking, but it doesn't even TRY to start. No hickup, no backfire, nothing. We have verified powers and grounds to the computer. I have tried a different computer. We have verified that it has the correct flexplate installed. We have verified that the distributor is installed correctly.
HELP??? hahaha Any other ideas?
Thanks
John
Thanks
John
