custom rear bumper tire carrier
MrMom
North GA
Like it says...it just needs a little welding modification to put the carrier back on but nothing major I assure you basically two tabs
I took the carrier off for a short time
Has square stock that go up as tail light guards and it wraps around the rockers
very beefy
Carrier has jerry can/bracket included also holds a hi lift
I need $ $200 for it.
PM me a address for pics
extra info.........
It is made of 2x6 box tubing with 2" id uprights
and 6 " c channel that wrap the sides
D rings welded on as well
Could easily double as a air tank just need a hole and fitting
I will even throw in couple large shackles that fit it
The uprights I had to cut down some to fit on my 96 to clear the hatch
It came off a 97 so it will fit either year
On the carrier you will need to reweld a few of the hinge tabs to accept the carrier
It should not be a big deal
I don't know about shipping prob would have to do freight
on a pallet it is heavy over 100 lbs I am sure
even with shipping it is probably a good deal compared to whats out there
