Old October 23rd, 2005, 16:53
2qk4u 2qk4u is offline
alignment issues
Have any of you had problems getting your xj aligned after installing the lift? I just installed a 4.5 RE lift on my jeep and had it aligned and no one can seem to get it right. It still wants to drift to the right. has anyone els had this problem? First off i installed the lift, put my new 32's on it and drove it. it seemed to go pretty straight other than the steering wheel was off about 90 degrees. so i went and got it aligned like you should do. when they aligned it the pushed the lower control arme foward to get caster adjustment and when he did that he didnt have any shims to fill in the gap on the aft part of the lower control arms. i had it aligned on the stock tires so they would scuff up my new wheels. some people said it didnt matter what tires i had on for the alignment. so when i drove it home it did ok. i put the 32's on and it pulled bad to the right. i didnt like how they didnt put any shims in the lower control arms. i decided to take it somewhere else that delt with lifted vehicle. they ended up pushing the lower control arms back the th normal position and messes with the toe and its a little better, but it still wants to drift to the right. im really worried about tire wear issues later down the road. Is anyone having tire wear problems on there xj? any advice is highly appreciated
thanks
Old October 23rd, 2005, 17:49
53guy's Avatar
53guy 53guy is offline
Re: alignment issues
are those arms adjustable? Sounds like you are having a castor angle problem. Mine did the same thing when I first put my lift on. I went to sears and bought me a 3 dollar magnetic protractor and did my castor angle myself and then had the shop do the toe in so I could get a print out of the angles and measurements. Try measuring your castor angle first. The tires shouldn't have anything to do with your jeep pulling to the left or right unless they are unballanced, mounted wrong, or in some other way messed up. I donno, just my 2c.
Old October 23rd, 2005, 19:09
60thAnivrsryXJ's Avatar
60thAnivrsryXJ 60thAnivrsryXJ is offline
I think that you should try having it aligned with the 32s on it. The bigger tires will make the jeep sit higher and what I have been taught is that all the alignment angles change when ride height changes. That is why the first step to an alignment is to make sure the tires are inflated to the right pressure because if one is low it'll affect the height of the vehicle.
Old October 24th, 2005, 00:45
Gojeep's Avatar
Gojeep Gojeep is offline
Just do it yourself. I show how to make the shims and all and they are dead simple to do in a few minutes flat.
www.go.jeep-xj.info
Old October 24th, 2005, 08:17
for all of you with lifted xj's , do most of you have some kinda thick shims in the rear of your lower control arms. basically what im trying to say is your control arms shove forward, so you need shims to take up the space. its where the 12mm nuts with studs are on the rear section of the lower control arm. i got fixed control arms with the RE 6130 lift and the only caster adj. is in the rear part on the control arm, with shims. if your not sure could you look please and let me know. just trying to get an idea how important it is to have it shimmed like that
thanks
Old October 24th, 2005, 08:22
old_man's Avatar
old_man old_man is offline
Swap the front tires side to side and see if it follows the tires. It is fairly common to have a tire that causes a pull.
Other than that, do a search on tape measure alignment and do it yourself.
Tom Houston - Former Colorado Chapter President, current Treasurer , Terminal Adrenaline Junkie, and Rocket Scientist
Loveland, Colorado My teardrop build
You're just jealous because the voices don't talk to you.
backyard alignment issues help... BUCKYXJ Modified Tech Discussion 7 March 19th, 2005 00:52
just don't go to sears? Alignment Issues... muduck18 Modified Tech Discussion 3 October 25th, 2004 00:50
alignment issues Prepmech Modified Tech Discussion 4 April 18th, 2004 10:27
alignment??? dellstopjeep OEM Tech Discussion 1 December 8th, 2003 14:35
HELP! Alignment issues....... Ted Z Modified Tech Discussion 15 October 2nd, 2003 05:06
