Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Other Technical Forums > JeepSpeed, Prerunner and Competition Tech Forum
JeepSpeed, Prerunner and Competition Tech Forum For Discussion of Modications related to Prerunning, JeepSpeed, KOH, Rock Racing, and any other speed based competitions
View Poll Results: Drop Brackets or Adjustable LCAs (short)
Drop Brackets 7 46.67%
Adjustable LCA's 8 53.33%
Voters: 15. You may not vote on this poll
Old June 30th, 2010, 15:34
kidarkitect's Avatar
kidarkitect kidarkitect is offline
Wannabe Jeepspeed/Overlander LCA/Drop bracket question
Hey all,
I have a 89 xj with 1.75 spacers, and v8 zj springs totalling me out at 3" of front lift. Tera swaybar disconnects, no rear sway bar. RE1600 track bar to be replaced with IRON Rock double shear track bar.
Currently, I'm running stock control arms and factory brackets. I'm trying to decide between adjustable shortarms like re3720's or some drop brackets like (looking at rocky road's) which would you guys think would be better.
I know its far from a real jeepspeed but its what I can afford and afford to maintain. So longarms and better springs etc are out until the student loans are paid off.... and I drive it more like a jeepspeed (within its limits) so that counts for something right?
I tend to seek the go fast more than I do the go slow(crawling) but still consider clearance to be important too so I'd like to hear what your guys opinions would be. Will the dbs fixing the castor make a huge difference in handling and dw prevention to make it worth the loss of clearance?
I am experiencing some death wobble currently when I get goin too which is the spawn of the front end rebuild I'm starting on.
Thanks in advance. And this isn't supposed to be a DW thread- just opinions on a mild jeepspeeder. So please no flame
Old June 30th, 2010, 15:37
silverslk's Avatar
silverslk silverslk is offline
Re: Wannabe Jeepspeed/Overlander LCA/Drop bracket question
What tire size are you running? I know most guys running 33's or 35's don't worry much about the DB's loss of clearance. If you are on 31's with your 3" lift it may be an issue. I would think at 3" you should be fine with adjustable control arms for now.
Old June 30th, 2010, 16:09
Just 30x9.5's at the moment. When they're worn out I'll be going to 31's.
The tires came on some Ravine wheels brand new and were still cheaper than anything at a tire shop so thats why I'm rollin em.
Old June 30th, 2010, 16:18
jeeperjohn's Avatar
jeeperjohn jeeperjohn is offline
I say control arm angle is more important for a good ride. So drop brackets.
Old June 30th, 2010, 16:49
xcm xcm is offline
neither.
if you must replace the control arms (maybe you need new bushings, and dont want to bother with stock, i get that), go ahead. but at 3", your control arm angles arent a problem. un-ideal? maybe. problem? doubt it.
track down the death wobble issue FIRST, dont just throw money at it (unless thats cool with you). im not flaming you, but i cant provide the type of information on dw, that you could easily find in a search.
whats wrong with the trackbar? i would MUCH rather run a RE peace, than some iro junk. if the bushings bad, BAM. theres your dw.
Old June 30th, 2010, 17:04
Bushing and frame side joint seem fine, (even hady friends at big o tires double check me to make sure I wasn't missing something) like the idea of a double shear setup but re's didn't won't fit. If I do the db's I'll replace the bushings at the same time. But I want to improve the on/off road handling as I tear thru it. Definitely not trying to throw money away, checked a few reviews of that track bar and it seemed like a win.
The main q is just wether the drop brackets are going to improve handling enough to lose the clearance.
Oh and yeah thanks for not flaming.
Old June 30th, 2010, 18:00
xcm xcm is offline
the ride/angles at 3" isnt bad. sure, its not an M3....
drop brackets make the ride smoother when you get PAST 4" or so, once the angles get downright bad.
in your situation, i'd source some used control arms. adjustable if possible... if not just aim for the arms they put in a RE 3.5" kit, i run the re non adjustables. track down the death wobble... if you still feel like spending money, pickup some good shocks. much better bang for the buck, IMHO.
drop brackets will make the ride better, but how much so is debateable. i wont run them because i see it as a band-aid ghetto fix, that some idiot engineer figured out would sell.... i 'GET IT' that not everyone has wild xj builds going on, and not everyone wants a long arm setup.. but once you purchase the drop brackets, the arms to fit them... etc etc etc... you're up around $500. $500 that would be better spent on long arms!
Old June 30th, 2010, 19:20
FatCity Ryan FatCity Ryan is offline
Adjustable lower arms. That's if caster is your death wabble problem. The stock mounts/ lowered mounts/ long arm discussion is another topic.
Old June 30th, 2010, 19:38
Ryan93 Ryan93 is offline
with only 3in lift my vote adjustable lowers, if you get drop brackets your probably going to need adjustable lowers anyways.. at least i did
Old July 1st, 2010, 07:07
Loose_Nuts_Enterprises's Avatar
Loose_Nuts_Enterprises Loose_Nuts_Enterprises is offline
With a 3" lift, and drop brackets, your control arms will almost be going uphill to the axle mounts. Get some adjustable arms, and change all the loose/worn steering components, ball joints, track bar etc. to find your wobble. Don't forget to check your toe and tire balance.
Old July 1st, 2010, 10:37
J Money J Money is offline
I had some death wobble and some gnarly noises. The lower track bar mount was ovaled out, bushings were worn, and my ball joints were dust. I fixed those items and my heep is nice and tight now.
Old July 2nd, 2010, 15:43
jeeperjohn's Avatar
I agree with that. The ride with long arms is worth the extra cost to me.
Old July 4th, 2010, 10:10
Thanks guys, yeah i'm pretty sure its coming from bad bushings in my control arms. I think I wore them out having a little too much fun on some Navajo Reservation roads when I was down there in May. Possibly the OEM track bar bracket(seems to actually be movement there, wierd). Everything else is tight as can be. I'll be change out the bushings and the track bar setup, then if the prob's fixed, start shopping for some LCA's.
Thanks again for the help !
Old July 12th, 2010, 22:26
karstic's Avatar
karstic karstic is offline
Not weird, but common. Crank that thing down.
Old July 15th, 2010, 20:22
ert01 ert01 is offline
I'm at 4.5" and I would not run DB's on a much lower lift then that... my arms are darn near perfectly horizontal now and if you were 1.5" lower, then your arms would be angling up even... the loss of clearance could be an issue too. I would say go with the adjustable arms at 3" if you plan to stay at that height.
Rate This Thread:
my "wannabe jeepspeed" grand cherokee build grandrunner JeepSpeed, Prerunner and Competition Tech Forum 157 July 1st, 2014 03:48
C.A. Drop Bracket Question SUA SPONTE Modified Tech Discussion 24 October 18th, 2009 15:44
drop bracket question Blakemore00xj Modified Tech Discussion 6 August 30th, 2009 23:31
Drop bracket question 98CherokeeSport Modified Tech Discussion 2 March 19th, 2009 20:11
RE Drop Bracket Installation Question? Begster Modified Tech Discussion 21 August 18th, 2007 09:06
