For an o/c up to 96. 40 in. long x 8.5 wide these are the top where it meets the headliner. The rear opening for the lights is 5.75 long x 5.5 wide. The front opening is 6.25 wide. This is all that I had written down for reference.
thank you, so you think a 5 in. to a 7.2 in screen should work, i know i willl have to modifie it for it to fit so bigger means more mods, smaller means less mods, thank you, your awsome, your help will be used alot, ahha thanks
Sure it can be done to look really nice and when not in use no one will know it's up there. Measure twice (atleast) and cut it right the first time. Good luck!
