Old June 27th, 2008, 11:34
menos menos is offline
Overheating with A/C
I'm having a problem with my '91 overheating. It's only started now that the temps here are hitting 100+.
Symptoms-
Temp will start creeping up above 230 on both the highway and city streets. Turning off the A/C will yield a reduction in temp. While on city streets this reduction is pretty gradual but on the highway it is pretty pronounced.
The truck has a new 3 row CSF radiator, new water pump, all new hoses, new fan clutch, new dealer thermostat.
I do not notice an unusual drain on the power of the motor when the A/C kicks on, and the A/C seems to be cooling normally.
The higher temps only show up if I've been on the road for more than 30 minutes. Trips shorter than that do not result in higher than normal temps.
At no point do I notice any loss of power, so I'm thinking that the cat might not be the problem.
Should I be focused on the A/C compressor or could it be that that is enough load to push a system running on the edge over it?
Could there be another source of the excess heat? Tranny maybe? If I rig up a temp sensor for the tranny where should I mount it?
Old June 27th, 2008, 11:38
mjma's Avatar
mjma mjma is offline
Re: Overheating with A/C
check to see that your electric fan kicks on when the AC compressor kicks on. Otherwise it may just be that your cooling system can just barely do it's job without the condensor working. Once the condensor starts transfering heat, the radiator can't cool the coolant down enough. This is when the fan should kick in to help pull more air....
Old June 27th, 2008, 11:49
stewie's Avatar
stewie stewie is offline
x2 on checking the electric fan. also, did you completely change the coolant when you did the radiator? how is your coolant level, and how does the coolant look? does your cooling system need to be burped? my 95 would come close to overheating after i did the waterpump and again with a CSF 3 core. it turns out that it needed to be burped. i lifted the red safety lever on my rad cap slightly and a bunch of air went into the resevor tank. after all the air was out, it was cooling much better.also, have you hosed out your ac condensor in front of the radiator? if there is even just a little bit of debris in it, it could severly affect cooling capabilities. be sure to just use a garden hose, no pressure attatchements.hthstewie
Old June 27th, 2008, 11:55
Gritts's Avatar
Gritts Gritts is offline
I have not Confirmed, or I used a BAD email Addy
I think the 91, like my 90 has a closed coolant system. Assuming you haven't converted yours to an open system, you may have air in the cooling system. After driving the Jeep let the engine cool down for at least 20 minutes and then CAREFULLY burp the system by opening the cap on the surge tank (just a few turns) to let out the air. Retighten cap. You may have to do this procedure more than once.
Oops, didn't see Stewies post.
Old June 27th, 2008, 15:19
Slo-Sho's Avatar
Slo-Sho Slo-Sho is offline
No mention of a new radiator cap?
Old June 27th, 2008, 16:44
89CherokeePioneer 89CherokeePioneer is offline
The 91 has a conventional radiator cap-in the sense that it's open.
May want to burp, hows the coolant looking? Turn the A/C on and see that the electric rad fan is spinning-it probably is or A/C wouldn't be all that effective.
Old June 27th, 2008, 17:30
Electric fan control is bypassed and is always on. All new coolant at 45/55 mix. New radiator cap. Open system. It is burped. I am frustrated
Old June 27th, 2008, 17:33
Slo-Sho's Avatar
Is the belt tight? Look at the serp belt when the A/C kicks on and see if it's loose.
Old June 27th, 2008, 17:36
Smittty9785's Avatar
Smittty9785 Smittty9785 is offline
you from SLO by any chance?
Old June 27th, 2008, 17:43
igotanxj igotanxj is offline
Theres gotta be an air pocket in there somewhere, its the only think it could be unless you have some faulty part. The air pockets don't always work their way to the front top of the radiator. Ask around if someone you know has an air lift to put the cooling system into a vacuum before its filled, its saved my behind more than a few times. You have to completely drain it to work best tho.
http://www.brandsplace.com/0246-uv-550000.html
Old June 27th, 2008, 17:51
jpcherokeekid's Avatar
jpcherokeekid jpcherokeekid is offline
chuck the a/c condensor, convert compressor over to oba, and remove doors. thats what i did.
Old June 27th, 2008, 18:52
Ecomike's Avatar
Ecomike Ecomike is offline
NAXJA# 2091
I would replace the radiator cap next (even if it is new replace it, get one that does not have the lever bleed valve on it!!!), at least 16 lbs, maybe even try a 17 or 18 lb cap, and make sure the E fan is not cutting out only durring the overheating episodes. maybe the fan or relay cuts out after a certain time, overloaded overheated electrical wire connection perhaps!!!!!!
Check for some partial restriction in the exhaust, or an engine running too lean. Exhaust leak heating the tranny, tranny fluid and eventually the radiator?
Also make sure you have the AC on Max, not on normal, and make sure the damper is closed to outside air and that the blend door is not letting the cool air reheat some from the heater core. Any of those can add overheating loads to the system.
Quote=8Mud: "Go ahead and put up the best fence you can build, I'll bet on some Mexican with a few dollars of nails and a pile of scrap lumber."
34 MPG , '85 2WD Cherokee Pioneer with custom installed, 64 hp, 2.2 L Nissan SD22 Diesel 5 spd Manual; & 4 Renix XJs, '87 Wagoneer 4.0, 4WD, 89-Cherokee, 4WD, '87 Cherokee 2WD, & '89 Cherokee Pioneer 2WD, all 4dr. #2091
Old July 21st, 2008, 15:20
Well, after the temps here have gone up past 100 I've noticed that the problem is even worse than before. Having the A/C on makes the engine temps go up faster but it is still overheating without the A/C on. Today I ran home from work with the A/C off and the engine temps got up to 230 or so.
I've got a transmission cooler and temp gauge that should be here soon and I'll see if the cooler makes any difference. If that doesn't help I'm gonna try hood vents, but after that I'm lost.
Old July 21st, 2008, 17:25
my2monkeys my2monkeys is offline
Don't forget your basics, like the boys say. Check bott. hose for spring inside, check pump flow at fast idle, and feel rad. hose when hot and make sure t-stat ain't malfunctioning.
Old July 21st, 2008, 21:34
1familyxj's Avatar
1familyxj 1familyxj is offline
I am having a similar problem. New CSF 3 core radiator, new radiator cap, new 180 t stat, New Flow Kooler Waterpump, and new engine (less than 200 miles on it). Mine overheats mostly in overdrive it seems. I have a high flow t stat and housing on order. Not trying to highjack your thread I just didn't want to start a new one since our problems sound similar.
overheating still evrydayXJ Modified Tech Discussion 17 September 6th, 2006 09:35
Overheating...sometimes...help BOLO1994 OEM Tech Discussion 3 July 22nd, 2006 20:17
Still overheating - what else is there? 90Pioneer OEM Tech Discussion 19 June 27th, 2006 16:35
MPG and Overheating rckclmbr OEM Tech Discussion 8 May 10th, 2006 08:23
overheating off and on mgt Modified Tech Discussion 11 June 29th, 2005 23:05
