OEM Tech Discussion Forum for OEM (Original Equipment) or stock XJs and MJs. |
Thread Tools | Display Modes |
#16
Re: AW-4 Auto Transmission direction of fluid flow
If you add a filter, make sure it has a pressure bypass.
#17
The numbers I posted earlier are the max pressures. In Reverse, parking brake on, wheels blocked, wide open throttle.
The numbers at idle are significantly lower. (6) Shift transmission into D range and note line pressure with engine at curb idle speed. Pressure should be 53-to-61 psi (363-to-422 kPa). (8) Shift transmission into Reverse and note line pressure with engine at curb idle speed. Pressure should be 73-to-87 psi (500-to-598 kPa). However, also bear in mind these are at the test port, not the outlet. I could not find any mention of pressure testing at the outlet itself. The outlet itself only needs enough pressure to push the fluid through the cooling circuit.
1988 Laredo 4L 2wd Auto, AKA "Grey Ghost", 208K |
#18
Excellent point. In this regard, the only pressure will be due to the fluid viscosity relative to the passage dimensions.
#19
This I've been unable to confirm, maybe will try next time I have the pan off!!!
#20
I agree, pressures are those expected at the pressure test port and not necessary the pressures in the cooling circuit.
The pressures mentioned can be seen in the operator's manual page 7,8 which gives the pressure measurement location as "test port". Link to manual is shown below. "discharge straight into the pan" is an excellent clue. The interior of the transmission runs at atmospheric pressure due to the vent at transmission top. So the pan pressure is atmospheric and at least the pressure at the return point is known. Unless someone has a more certain cooling circuit pressure, I'm going to keep to my transmission line hose and hose clamp rig. Thanks for replies! https://cdn.xjjeeps.com/pdf/en-us/aw...nformation.pdf |
#21
Here's another link to a cooling circuit pressure discussion... but no definitive answer.
https://www.naxja.org/forum/showthread.php?t=968375 |
#22
I decided to get a answer to this and my fuel pressure. I have a #6 test port coming tomorrow!
#23
I guess you mean a -6 AN test port? Gonna put it at the trans outlet and inlet and/or cooler inlet and outlet?
#24
I will do everything at the trans because it's easier and I have a SAE quick-connect on the radiator. The gauge is electric so I will be able to read the pressures under all load conditions. Same is true for my fuel system but using the quick-connect .
#25
Very nice! Very clean!!
#26
My e-fans have done me well for the almost twenty years I have been using them (twin Derale with an advertised 4,000 CFM).
Patrick ![]() 1996 XJ; 4.0L; AW4; NP231; SYE; D30 and D44; ECTED; 4.10 gears; 30X9.5 -15 BFG/AT/KO; 3" lift; Rusty's LCA; JKS ADJ UCA; Kevins ADJ Track bar; Drawtite Front Receiver; Dual Electric Fans; Dual Battaries. |
#27
It's a Griffin that came with the shroud but I use the factory design because of the mechanical AND electric fans.
Thread Tools | |
Display Modes | |
A4W Fluid Flow | dktool | OEM Tech Discussion | 3 | November 20th, 2013 12:43 |
2000 xj classic 2wd auto transmission and fluid | phxZ31 | OEM Tech Discussion | 10 | January 17th, 2013 15:51 |
Coolant flow DIRECTION..? | XpedientJ | OEM Tech Discussion | 6 | October 27th, 2008 11:52 |
Remote Transmission Filter: Flow/Pressure-drop issues?? | XpedientJ | Modified Tech Discussion | 16 | March 30th, 2008 20:00 |
fluid flow vs cooling | bj-666 | Tow Rigs and Trailers | 1 | March 1st, 2008 09:02 |
