Old August 24th, 2012, 07:17
clean96XJ's Avatar
clean96XJ clean96XJ is offline
Re: 96 XJ Overheating
Like the idea of installing
the Taurus fan in FRONT of the radiator.
Since you have it and likely still have the wiring.
Cheap and easy experiment which could solve your problems.
fixing the exhaust leak might help too.
Ever consider taking/monitoring the underhood temps?
A few people here have posted their underhood temps would be nice to compare.
Old August 24th, 2012, 09:50
87manche's Avatar
87manche 87manche is offline
What are you basing your overheat on? The factory gauge?
It may be faulty.
I'd double check it with an IR thermometer when it says it's hot.
That said.
i'd start with the exhaust leak. If it's affecting your o2 sender it may have a crazy fuel mixture.
Cat plugged?
tried it with a test pipe?
everything new, and yet still overheating! mxracer624 OEM Tech Discussion 21 August 13th, 2010 11:09
Overheating... STILL Tenny OEM Tech Discussion 51 July 27th, 2009 13:32
Overheating ChrisSanchez OEM Tech Discussion 6 May 28th, 2009 14:26
overheating!!!!!!!!!!!!!!!!!!! rcliftedXJ OEM Tech Discussion 9 May 26th, 2009 12:36
overheating ChipsXJ OEM Tech Discussion 14 January 26th, 2006 21:13
