Old September 28th, 2010, 12:06
hidesintrees's Avatar
hidesintrees hidesintrees is offline
power steering pump is dying!!
..and im going wheeling this weekend, im about to head to the junkyard, what swaps are there out there? ive heard grand cherokee pumps are stronger and a direct swap? any truth here? or should i just get a stock replacement and call it good?
1990 4L-i6 with durango steering box turning 36s..
Old September 28th, 2010, 12:39
old_man's Avatar
old_man old_man is offline
Re: power steering pump is dying!!
I went with a pump from a 2001 Grand Cherokee and run the Dakota box. It is a bit twitchy going on the highway. Even adding the hydro assist didn't calm it all the way down.
Old September 28th, 2010, 13:26
Boostedballs Boostedballs is offline
How do you know it's bad? A lot of times they just scream if the fluid is low and the fluid becomes foamy. Filling it up and running the steering from lock to lock 3 times usually gets the air out.
Old September 28th, 2010, 23:06
cuz i always check the fluid cold and hot and its progressively gotten weaker over the last year. and it screams perty bad
Drive with dying power steering pump or remove belt sbilbrey OEM Tech Discussion 7 December 3rd, 2009 04:25
Power steering pump dying? UltimateG OEM Tech Discussion 8 October 31st, 2007 13:10
power steering pump fluidmotion Modified Tech Discussion 3 May 15th, 2007 12:35
What does a dying power steering pump sound like? johnsoninc86 OEM Tech Discussion 5 April 18th, 2006 10:11
Thread size/pitch of power steering pump/steering gear inlet/outlet? hotrod22 OEM Tech Discussion 7 January 16th, 2006 12:38
