Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Other Technical Forums > Tow Rigs and Trailers
Tow Rigs and Trailers Hey, not all of our Jeeps are great on the highway. Post here for tech related to getting your XJ to the trailhead.
Old March 30th, 2023, 20:44
Anak's Avatar
Anak Anak is offline
Stranger
How Much Clearance for Trailer Fenders?
Google gets me answers ranging from 3 fingers to 4" of clearance. Quite the range.
I am hoping I can get better answers here.
Trailer is a tandem axle car hauler which has had the axles/springs modified from spring under to spring over. Fenders are now ridiculously high relative to the tires.
I want to get the fenders down as low as is reasonable, and yet still not have the tires rub. The challenge is being able to open and close the doors on my GTA, but the trailer has to be able to handle back country dirt roads with lots of rocks and ruts (much like Cleghorn and the 2N49 for those who know San Bernardino trails).
Old March 31st, 2023, 10:08
Rob Mayercik's Avatar
Rob Mayercik Rob Mayercik is offline
NAXJA Member #920
Re: How Much Clearance for Trailer Fenders?
What about modifying the fenders to be removable, so you can pop them off when you're trying to get in/out of the GTA?
1992 Cherokee Laredo: "A wonderful balance of grace and rust"
1984 Dodge Omni
2002 Volkswagen Jetta GLS TDI
Old March 31st, 2023, 11:11
Anak's Avatar
Stranger
The problem with removable fenders is that they are weak.
They don't hold up well to being walked on. Or dragged around trees/rocks.
I have thought about it, but I can't come up with a reasonable design that is removable and yet capable of holding up.
Old March 31st, 2023, 13:43
JohnX's Avatar
JohnX JohnX is offline
Sarge
On my trailer I have under 2" of tire clearance when loaded with a jeep. I have never experienced rubbing issues. I did have a center shackle wear through the pivot bushing....to the tune of 2". That effectively lowered the clearance to 1" at the fender when loaded....I began to notice rub marks on the tires but did not cause any significant wear or damage.
Overall, I would say 2 inches clearance while loaded should be sufficient.
So Cal Vice President
LGBFJB
Old April 2nd, 2023, 06:57
Anak's Avatar
Stranger
Thank you John. That sounds like a reasonable distance.
I think I will pull the Suburban (3/4 ton, 4x4, 8.1L) up on the trailer and measure from there.
Old April 2nd, 2023, 12:04
JohnX's Avatar
Sarge
I believe the heaviest vehicle I had on mine while it was damaged and riding low was my tahoe. From Albuquerque to LA with no issues.
LGBFJB
Rate This Thread:
WTT: XJ fenders with TJ flares for stock XJ fenders NJblackdeath4x4 NAC Classifieds 10 July 29th, 2011 02:29
Feeler: Ajax / Trailer Products glass fenders crazyjim SoCal For Sale 20 May 16th, 2010 12:52
6x16 deck over trailer for sale(snowmobile trailer) pajeepman NAC Classifieds 0 February 17th, 2010 13:23
Just installed 4.5 RE lift but don't have even clearance on front fenders Ewen91 Modified Tech Discussion 9 July 16th, 2009 21:09
