Prev Previous Post   Next Post Next
Old September 28th, 2022, 10:05
truckeejeeper's Avatar
truckeejeeper truckeejeeper is offline
Diagnose rattle under shift knob?
So - I just had my shop (been using them for 20 yrs.) put in a new clutch (LUK) on my 1991 4.0 4x4 5 speed about a month ago. Everything new under there, master, slave, flywheel, bearing etc. Recently thought, I've started to hear a squeaking/rattling that sound like its right under the shift knob/shifter unit. The sound comes when I push in the clutch pedal/disengage clutch (like at a stoplight.) If I shift it into neutral and let up the pedal, sound goes away. Push in pedal and shift into gear, sound comes back. I can't tell if the sound is there while driving (no carpet kit, its pretty loud) but I assume it is. Sound is like a chirping/squeaking, little bit a rattle. Like something isn't lubed or tight or both. What is this noise? It's new for sure. Was there before new clutch, or right after clutch install. May be getting louder.
Thanks for any ideas
- TJ
Please help diagnose rattle/clunk on startup (video) yzmuddereffer OEM Tech Discussion 6 September 21st, 2012 15:02
Shift Knob noresttill OEM Tech Discussion 7 February 3rd, 2010 11:37
Shift knob Mdub OEM Tech Discussion 15 April 2nd, 2009 20:35
shift knob needed solditforajeep Modified Tech Discussion 1 August 26th, 2006 11:21
shift knob Wondo Modified Tech Discussion 3 May 23rd, 2005 14:19
