Old October 22nd, 2017, 07:47
4x4JeePmaNthINg's Avatar
4x4JeePmaNthINg 4x4JeePmaNthINg is offline
traction bar, when is it worth adding?
is a traction bar worth adding or not worth adding for any particular tire sizes small or large.
im on 33's now and I am curious of this addition and if it is worth investing in for its traction improvement.
it would be added to a C8.25 29spl and i would need a new or additional modified cross member for mounting.
also are there any cons to this set up?
i appreciate any info
Old October 22nd, 2017, 08:23
RCP Phx RCP Phx is online now
Re: traction bar, when is it worth adding?
I've never seen the need on any of my XJ's. I have built a couple for other vehicles but it mostly depends on your spring pack. There are no downsides to a properly built one.
Old October 22nd, 2017, 08:31
ehall's Avatar
ehall ehall is offline
I need one, 6" of lift with extended shackles and relocators, the shackles let sooo much movement in the springs now.
my '91 beater rebuild
Old October 22nd, 2017, 09:47
Green XJ Jeep Green XJ Jeep is offline
NAXJA Member 4950
Are you having an issue with wheel hop or axle wrap?
If not then it really isn't going to help with traction.
Old October 22nd, 2017, 11:10
1990JEEPXJ's Avatar
1990JEEPXJ 1990JEEPXJ is offline
There are no cons to one. I built one because I broke a driveshaft trying to bump up and over an obstacle. Plus I have pretty worn out leafs and long shackles with relocation brackets
Old October 22nd, 2017, 12:56
Boostwerks.com's Avatar
Boostwerks.com Boostwerks.com is offline
NAXJA Supporting Vendor
Having twisted a couple leaf packs, I'd never go back to not having one.
[IMG]IMG_1980 by Bryson Whissen, on Flickr[/IMG]
IMG_2174 by Bryson Whissen, on Flickr
99 XJ Sport Build Thread:
http://www.naxja.org/forum/showthread.php?t=1059015
Check out our website!
www.BoostwerksEngineering.com
Old October 23rd, 2017, 11:51
burntkat burntkat is offline
NAXJA Member #1145
It's hard to tell, is that near the diff?
-89 S-10: SAS, D44s front/rear. 5.7L V8. 700R4 with 4L60E upgrades. Built in my driveway.
-90 XJ 4.0, AW4, 231J: Clayton's longarms, RE 5.5" coils, hybrid 6" leaf pack, 33/12.50/15" MTs, Rancho 99012s and 99624s, Tera HD SYE, custom sliders, BW flares. Rehabbing with D44s, RE spring packs, RE 4.5" coils, and ACOS.
-94 ZJ: Budget boost, 31s. The wife's DD.
-97 XJ: Son's DD. 4" lift, ACOS, 4" spring pack, Upcountry coils, 31s
Old October 24th, 2017, 05:12
themauler's Avatar
themauler themauler is offline
Yes. Closer to the center of the diff/axle the better homeslice.
Nick Maul,
Just want to build something that won't break on the trail
Old October 24th, 2017, 05:38
NAXJA Member #1145
I don't know who the hell homeslice is, but thanks for the reply.
Old October 24th, 2017, 11:18
Yup.
IMG_1975 by Bryson Whissen, on Flickr
Old October 24th, 2017, 13:26
NAXJA Member 4950
In the context used you are homeslice.
Homeslice,
synonomous to "homie".*
def 1: means good friend or buddy*
def 2: means someone who seems like a little slice of home, thus home slice*
Old October 24th, 2017, 16:20
ftwelder's Avatar
ftwelder ftwelder is offline
Homeslice went around in '05. The name burnkat conjures up sort of a beatnik/ hipster vibe which suggests you may be familiar with this nomenclature.. haha.. sorry..
endless jeep project that will eventually end up as a rust bucket in someones backyard.
Old October 25th, 2017, 07:31
NAXJA Member #1145
Yeah, you couldn't be more wrong. If I had my way they'd all be euthanized in vitro.
Old October 30th, 2017, 19:40
1990JEEPXJ's Avatar
So I changed up the design of mine. I have a flat belly and want to keep it that way. My old traction bar had a shackle but it went through the floor which I wasn’t too fond of. So I made a slip and twist design and the shorter bar is completely adjustable. It’s built like a radius arm. Much more compact without the shackle. Only possible downside would be a hard hit bending it and therefore not allowing it to slip and twist. We will see how it goes
Old October 30th, 2017, 22:42
kcox506's Avatar
kcox506 kcox506 is offline
Traction bar is the only answer. Especially with a manual. All of the torque transfer. Its super fun.
Ironman4x4fab Marketing Manager
2000 XJ ~4.5" '06 4.0
LP44 w/Rubi Air Locker & 8.8 ARB
231 w/ beefy stuff
Traction Bar RoyalXJ NAC Classifieds 0 November 27th, 2011 18:09
Traction Bar uncc civilengineer SEC For Sale / Wanted Forum 0 November 29th, 2010 16:46
More Traction trail rate this South East Chapter 14 September 4th, 2009 11:20
traction bar help gearwhine Modified Tech Discussion 0 June 18th, 2003 18:14
Traction Bar FJH97XJ Modified Tech Discussion 9 June 12th, 2003 14:10
