Rick Anderson
- Lusby, MD
My 5spd Shifter is somewhat dragging or sticking. I mean, it doesn't easily center, nor is there much spring bias that pulls it back toward center.
i.e. in nuetral, it doesn't pull back toward the center position crisply, if you push it over toward one side, it will tend to stay there or pull toward center slowly.
This is a problem, because on moving thru the "H" pattern as I shift, without the shifter having that solid feel or spring bias toward the center, its easy to mis-shift. i.e. I pull out of 2nd and move the stick to center and then forward to shift to 3rd, and I never really get the feel of the stick in the center, and sure enough I sometime end up in 1st or 5th instead.
This is on an '95 XJ, 2WD, 2.5L I4 w/ AX-5 spd manual. I'm just got it with 201k miles. Don't know when the fluid was changed last, but considering what I've seen so far, the trans fluid has never been changed.
Is this normal, is the AX-5 just weak on shifter feel?
Could the linkage be gummed up? Could the linkage internal to the trans be all gummed up?
I plan on changing the fluid in the trans with RedLine MT90, I'm assuming the Synthetic trans fluid would help free up any gumming of the internal shifter.
What about the rest of the linkage, is there a way to pull the plate at the top of the trans and clean up and lube the linkage up there? Can it be done, can it help at all? I ask, because I have the carpets out of the car at the moment, finishing up welding in patch panels on the floor. Before I put the carpet back in, is it worth it to take the time and pull all the covers off and try to get the shifter and that top panel off the trans?
