Madmanmarty
- PA
I need help!
'94 cherokee, 4.0 HO. just bought a few months ago. truck needs work.
OK so here is the history. i read thru many pages of heater info.
I had a heater motor that would only run on high speed. it squealed badly.
pulled the resistor. it was rusted.plug was OK. replaced resistor. motor ran on all speeds after resistor replacement,but still squealed, & resistor started to smoke. shut down quickly.
pulled heater motor. it would barely spin by hand. replaced. tested motor & resistor prior to full install,motor spins great, runs on all speeds, but after a minute on low fan speed resistor heats up & starts to smoke.
So my question is - after replacing bad resistor & motor(not installed, just plugged in), what would cause the resistance to heat up & burn out resistor. again resistor plug looks great. I may be having a ground issue, new wires from Jon (5-90) are on order. thanks for your help.
