Old June 12th, 2006, 15:02
langer1's Avatar
langer1 langer1 is offline
Re: Extended Idle 97-01 Install
Originally Posted by jeepinarkansas
Why would one want this option?
To keep your battery charging when parked and all your lights on.
Old June 12th, 2006, 15:14
ihscoutlover's Avatar
ihscoutlover ihscoutlover is offline
John, this is the only extended idle posting I found. Is there a way to get this information for a '96 and older-mine being a '94 XJ? I would like to make this modification if possible. I would also need schematics and the such. Thanks
Jeff
Old June 12th, 2006, 15:21
langer1's Avatar
94's are also covered. PCM12 is the connection point.
Old June 12th, 2006, 15:24
langer1's Avatar
For 1993-1995 I6 XJs:
PCM Pin # 10, Purple, [60-pin connector] (Switch On: 1V, Off:12V)
For 1996 I6 XJs:
PCM Pin # 12, dark blue/orange, [Black "A" 32-pin connector] (Switch On: 1V, Off:12V)
For 1997-2000 I6 XJs:
PCM Pin # 12, gray, [Black "A" 32-pin connector] (Switch On: 1V, Off:12V)
It has the Black 32 pin connector, not a 60 pin connector though, so I would assume it follows the later year models....
Old June 12th, 2006, 15:52
Then John do I just need the switch from a '96 or older unit? Thanks for the update
Jeff
Old June 12th, 2006, 16:46
langer1's Avatar
Jeff
You can use any switch you like.
Old June 15th, 2006, 00:57
John, then by your schematics, is the switch taking 12V away from the PCM or adding it to it to get the higher idle, and how does it get tied into the wiring since my '94 doesn't have it?? I kinda understand your directions, is it just a two or three wire switch?? Thanks
Jeff
Old June 15th, 2006, 05:09
langer1's Avatar
When Extended Idle is on it grounds pin #10. Not sure about what you mean about a three wire switch, if the switch has a indicator light is has three wires but one is just the light.
Old July 21st, 2006, 19:15
Blaine B.'s Avatar
Blaine B. Blaine B. is offline
Thanks for the information!
Old September 10th, 2006, 21:57
Blaine B.'s Avatar
How would I wire up a standard lighted switch (3 inputs) for this?
These switches have a ground, input +12, and output +12.
To get it to light when the switch is activated, how would I wire it? If I switched around the +12 and ground I don't think that would work.
When the extended idle is not activated, what voltage is it reading? If it was +12 then it would be fine to reverse +12 and ground.....if not, it wouldn't be ok.
Any ideas and do you know what I am asking? Thanks!
Old November 8th, 2006, 17:55
casm's Avatar
casm casm is offline
It seems like there's always a new reason to dig this thread up again...
Spent a good part of the afternoon cleaning up some ratty wiring I'd introduced by installing various things. Something I'm curious about:
If you look at the spliced wire on the PCM, you'll notice that in 2000XJSport's installation he left the other end of the wire dangling from where it originally exited the harness; I've got the same thing. Does anyone know where this wire terminates? I'd like to eliminate the stray ghetto wire I've got running to the PCM now and use the factory one if at all possible.
Yeah, I know that six months ago would've been the appropriate time to consider this, but I was just so giddy with enthusiasm at the idea of being able to raise the idle with the flick of a switch that the idea never really occurred to me
Old November 8th, 2006, 19:38
red_01_xj's Avatar
red_01_xj red_01_xj is offline
i left mine intact im not sure where it would go
Old November 8th, 2006, 21:01
Blaine B.'s Avatar
My 95 doesn't even have this wire in the plug. Any idea how to add it so I could run it to a switch?
Old November 8th, 2006, 21:59
red_01_xj's Avatar
the pre 96 had a differnet wiring
Old November 9th, 2006, 12:55
Blaine B.'s Avatar
I know, using the chart with Pin # for OBD I (for my 95) and corresponding wire color, I know my computer plug doesn't have that. I'd like to add it.....any ideas on how to add it to the plug if it doesn't already have it?
Extended Idle Switch??? RTicUL8 OEM Tech Discussion 49 March 24th, 2009 03:41
Extended Idle??? pa_muddin_xj OEM Tech Discussion 6 June 10th, 2005 21:54
Extended Idle??? Gridlin Jeep Street and Performance 1 March 23rd, 2005 08:40
WTB: Driver side vent, overhead console, and an extended idle switch bezel 90Pioneer Wanted: Private Party Only 1 January 30th, 2005 13:54
WTB: Factory Extended Idle switch bezel for pre 97 XJ 90Pioneer Wanted: Private Party Only 5 October 3rd, 2004 17:27
