Old September 2nd, 2020, 06:32
Evan03 Evan03 is offline
Re: Alignment help/Very poor steering
I agree with Rcp tht most kits come with cheap heims, but that does not men theyre bad.
Don't replace what's not broke
Also I noticed you said your drag link and track bar are close to parralell. Close means they not parralell.
I recently replaced my steering box i noticed the bot hoes on the inside of the frame ovaled out so Ive been paying more attention and found the frame flexes allowing the box to move.
So your drag and track bar are out of wack
Possibley moving steering box or even cracked frame.
Castor is a none wearing tire angle play with it till it drives how like you like. Visually eye pinion angle the more castor you have the worse the pinion angle.
Turning Cs would be fun project but doubtful its the solution to your problem
Old September 2nd, 2020, 06:44
RCP Phx RCP Phx is online now
With the 33's on there now, a steel steering box mount is a must!
Old September 2nd, 2020, 06:45
blu3fan's Avatar
blu3fan blu3fan is offline
im running 35's without a mount but I have Kevin's steering box mount
would recommend
Old September 3rd, 2020, 12:31
cwyman6 cwyman6 is offline
also check the steering shaft for binding or bad joints. Seen it before
Old September 10th, 2020, 15:54
sixditchoffroad's Avatar
sixditchoffroad sixditchoffroad is offline
AKA Skip
sounds like a track bar issue. replace the bushings/tre's. i do the tape measure alignment with no issue.
1996 Two Door - 4.5 Short Arm, RE Track Bar, WJ Steering, hp30 with 4.10s and an Aussie locker. 8.8 31 spline with discs 4.10s and a Lincoln locker. Rocksliders, front stubby winch bumper, 35" Coopers stt pros.
steering alignment condonsation SoCal Chapter 15 October 5th, 2015 08:34
Need some help - steering wheel alignment TRCM Modified Tech Discussion 9 December 17th, 2012 17:51
poor steering, bump steer, fixes? SoWalSurfer Modified Tech Discussion 9 December 27th, 2009 17:07
Steering wheel alignment Spidey OEM Tech Discussion 6 January 14th, 2005 10:14
Getting the steering alignment right Chancer OEM Tech Discussion 6 November 11th, 2004 09:29
