Old July 16th, 2020, 22:27
bajabronco bajabronco is offline
Lift Shackle Comparison Iron Rock Offroad Vs StinkyFab
I just got my new Stinkyfab Racing shackles and I thought I would give you guys a comparison to the Iron Rock off-road and a 5 Rubicon Express shackle I had laying around.
All 3 are 1/4 steel, but the SFR overall is bigger with the leaf ears and overall shackle being thicker. The 5" Rubicon Express shackle is pretty small, and does not have a boomerang angle.
All 3 are 1/4 steel, but the SFR overall is bigger.
The leaf ears and overall shackle being thicker. The round bushing bucket on the Stinkyfab shackle is 1/4 and the IRO one is 3/16.
You can see in the picture that the IRO shackle actually angles back after the cross brace, while the SFR one is straight, but achieves its boomerang kick back by the busing bucket being offset from the main body of the shackle vs the IRO one which is on the top.
I bent the crap out of my IRO shackle doing the Rubicon and Dusy Ershim last year. The SFR one looks beefier, I am hoping that the full body of the shackle being straight makes it stronger.
The length of the SFR from center of the bushing hole to the 2 leaf mounting holes is 5 1/2 and 6 1/2, slightly longer than the IRO one which is 5 and 6.
The IRO comes powder coated and the SFR comes as raw metal. The IRO shackles are $80.00 + shipping from Minnesota, SFR are $119, but ship from
San Diego. I live in California so shipping was a lot cheaper on the SFR shackle. I'll report back on how the SFR racing does once I get it mounted and bash it on some rocks!
Old July 17th, 2020, 04:51
whitexj98 whitexj98 is offline
Re: Lift Shackle Comparison Iron Rock Offroad Vs StinkyFab
I was comparing the IROs vs the SFR, glad I went with the SFR, looks like an overall better design, just got them on last night.
Old July 17th, 2020, 09:36
shortydog33 shortydog33 is offline
Nice and informative post, thanks. Did you look at or do you have any opinion of the Boostwerks Engineering Comp Shackle? Just asking as I am considering running them. Thanks
Old July 17th, 2020, 10:04
I did briefly look at the boostwerks shackle, but didn't consider it. I really like the inherent anti-sway properties of a shackle/leaf setup in the rear. When I looked at the design of the boostwerks shackle with the flex joint it seemed like the abundance of lateral movement that the joint provides would eliminate the anti-sway ability that the traditional setup has. I don't have a lack of flex in my rear, so I didn't think giving up anti-sway was worth it.
Old July 17th, 2020, 10:09
Thank you!
Old July 18th, 2020, 17:24
Anak's Avatar
Anak Anak is offline
Stranger
Beautiful rig.
Old July 18th, 2020, 17:33
Evan03 Evan03 is offline
I wonderd about tossing boostwerx in the mix to
Sweet rig what's on your hood?
Old July 18th, 2020, 18:15
It was a pad I was using when I crawled under the rig. I was measuring for new shocks.
Old July 18th, 2020, 18:19
RCP Phx RCP Phx is offline
I don't know what length that you needed but Rusty's are made of 3/8". I've been running the +.75" ones for 20 yrs and they make 1.5" ones.
https://www.rustysoffroad.com/jeep-s...able-pair.html
Old July 18th, 2020, 21:04
ehall's Avatar
ehall ehall is offline
I have been using these Clayton adjustable shackles for a few years and have been very happy with them. They are probably longer the SFR but may not be as strong. The Claytons also come with big LCA-sized rubber Clevite bushings, and I am a big fan of rubber over everything else.
my '91 beater rebuild
Old July 18th, 2020, 22:00
ehall, Clayton always makes really good stuff as well! I haven't seen their shackles on a rig in person before, but knowing Clayton I would assume they are solid. They are a little pricy though at a $150.00.
Old July 19th, 2020, 06:49
TRCM's Avatar
TRCM TRCM is offline
It also looks like the SFR shackle isn't greasable....
Old July 19th, 2020, 12:54
Anak's Avatar
Stranger
A man with a drill bit and a tap could probably fix that.
Old July 19th, 2020, 14:05
TRCM's Avatar
You could, but it wouldn't work like it's supposed to.....unless you remove the bushing and cut grooves in it for the grease.
Would also probably void any warranty on the part....
Old July 19th, 2020, 17:45
Depends on if bushings have grease grooves. Though I'd imagine even with out grease grooves adding a zero and running some grease would be beneficial.
I'm not to worried about parts having a warranty in the offroad world specially a shackle that Im planning to drag over sharp idaho rocks.
Iron Rock Offroad 3" Lift question Jeepfreco Modified Tech Discussion 0 October 20th, 2019 15:47
Iron Rock Offroad lift question Sluder Modified Tech Discussion 3 April 21st, 2015 09:06
XJ RC Lift and Iron Rock Offroad SYE, BOTH NIB jimmy21669 NAC Classifieds 3 June 21st, 2011 09:15
Iron rock offroad lift handling krawlingxj Modified Tech Discussion 20 May 2nd, 2011 12:45
Iron Rock Offroad 3 link lift kits, what do you think? BigPete Modified Tech Discussion 4 September 3rd, 2009 19:58
