Old September 16th, 2020, 12:33
xjdavid1 xjdavid1 is offline
TPMS
Which TPMS are people using?
Sent from my SM-N960F using Tapatalk
Old September 17th, 2020, 09:46
Rob Mayercik's Avatar
Rob Mayercik Rob Mayercik is offline
NAXJA Member #920
Re: TPMS
I use this: https://www.harborfreight.com/tire-g...ose-63955.html
Jokes aside, I don't know if TPMS is a common modification around here. I've seen a bunch of simple ones on Amazon that use special valve stem caps, but I've not tried any of them since the Jeep's a second vehicle and I prefer to just put a dial-type manual gauge on from time to time on my daily driver.
Is this something you're doing for the "gizmo factor", or is Australia doing something crazy like forcing you to refit a TPMS into a vehicle that not only never had it to begin with, but largely predated the concept (for civilian vehicles anyway, I think the military Humvees had them back then)?
1992 Cherokee Laredo: "A wonderful balance of grace and rust"
1984 Dodge Omni
2002 Volkswagen Jetta GLS TDI
Old September 17th, 2020, 15:13
Black1990jeep Black1990jeep is offline
Re: TPMS
tpms? Looks like a tire gage to me.
Old September 17th, 2020, 16:23
TPMS
I have destroyed 2 brand new MTZs in the last 6 months because clay got under the bead causing the tire to go flat. I didn't notice and continued to drive on it which ripped up the bead. I was thinking if I had an alarm to tell me when the tire was flat I could have saved myself a couple of MTZs. Maybe if I got some beadlocks I wouldn't need the TPMS.
Old September 17th, 2020, 16:37
RCP Phx RCP Phx is offline
Re: TPMS
If your running tire pressures that low, I don't any TPMS that would read that low to begin with. If that's the case then beadlock's are in your future.
Old September 18th, 2020, 09:40
NAXJA Member #920
Re: TPMS
It is a tire gauge. That was the joke.
1984 Dodge Omni
Old September 18th, 2020, 17:18
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Re: TPMS
Originally Posted by Rob Mayercik View Post
I use this:
Me too.
Go ahead and slam the liftgate down on a blanket, and see how long you are laughing.
TPMS for trailer tires seanR Non-Tech / Off Topic 4 July 27th, 2015 09:22
Hella TPMS FlexdXJ Modified Tech Discussion 4 March 29th, 2008 16:01
