OEM Tech Discussion Forum for OEM (Original Equipment) or stock XJs and MJs. |
Thread Tools | Display Modes |
Anyone know where these plugs go?
I have a 1992 Cherokee sport
been having a starting problem, i think one of these plugs is to the ignition but i cant figure out where any of them go...no apparent connections. 1. This blue plug fell down when i was working on the floor pan and it only has a few pins in it but looks like a 6 or 8 pin. It also comes off the harness from the firewall. http://i830.photobucket.com/albums/zz229/dark92xj/DSC01841.jpg 2. This little plug looks like a 2 or 4 pin that comes off the wire harness from the firewall also...its one of the only 2 plugs off the wire harness close to the firewall. http://i830.photobucket.com/albums/z...j/DSC01842.jpg 3. Last one. This plug actually comes out of the big wire harness that runs under the dash. Its a 4 pin but it only has 3 pins in the connector. The wires are White/Yellow, Green/Yellow, Yellow. http://i830.photobucket.com/albums/zz229/dark92xj/DSC01843.jpg Last edited by dark92xj; August 20th, 2010 at 09:11. Reason: pictures were all messed up |
#2
Re: Anyone know where these plugs go?
your pictures don't line up with your post at all. The only one that has anything electrical in it is the second, which pictures the transfer case or transmission shift bezel illumination lamp.
Fix the pics and I'll take a look again ![]()
My yard looks like Sanford & Sons. Current crapcan fleet: LS swapped bobbed 79 J10 Honcho, 4x4 auto 4.0 8.25 swapped metric ton 88 MJ CTeunuch: Sometimes I really wonder if this sport makes you insane, or it just attracts the mentally unstable. |
#3
sorry photobucket is pissin me off :P
#4
Try imageshack... easier to use and not so cluttered IMO.
#5
ok fixed
#6
I want to say the blue one is for the brake pedal switch but I'm not sure. I'll check my 91 FSM when I get home and see if it's close enough to be useful.
Next one not sure... accessory power maybe? Anywhere it goes in the fuse panel? Never even seen the last one ![]()
#7
I know my brake pedal switch connectors are plugged in so it cant be that...
the second connector only reaches about 8" from the firewall so it doesnt go to the fuse panel last one i have no clue either lol |
Thread Tools | |
Display Modes | |
plugs | POLmagnum | OEM Tech Discussion | 4 | October 1st, 2009 08:22 |
Help 2 of the six plugs still look new. | livewire | OEM Tech Discussion | 8 | October 7th, 2006 20:30 |
fouled plugs | jefftrucker12 | OEM Tech Discussion | 14 | August 22nd, 2006 17:26 |
Plugs.... plugs... plugs | Kejtar | Modified Tech Discussion | 14 | February 21st, 2004 11:54 |
Plugs? | Centrevillemx | Modified Tech Discussion | 13 | July 8th, 2003 08:21 |
