I have an 88XJ, AW4, NP242. I am trying to install new front calipers (already did the rear brakes) and I have a question about the bolts that hold the caliper on. Do they thread in and then hit the inner brake pad? Mine are going in and then pushing on the brake pad and then the caliper is still loosewith both bolts tight. This can't be right, can it? I don't see any other way to install them. Thanks for any help you can give. I'll try to get pictures later if you need them.
