Horn Relay? (Horn off with Ignition Off) 90XJ
RickyN29
Hey everyone,
Question for ya'll
Where the heck is the horn relay?!? I want to use the horn with my alarm instead of the siren. However, the horn relay is switched from the ignition switch. (Meaning that with the ignition off, the horn does not receive power)
I want to change the relay (pin 30) from Switched to Constant power. I cant find the darn thing!
Any help?
Unplug the horn wires and with the key on listen for the click when you try to blow the horn.
The BRN wire on your IGN switch pin A is the horn relay wire (30)
The relay should be under your dash, taped to the wiring harness just above the fuseblock.
